Water Pump - Fiberglass RV
Old 06-14-2009, 04:34 PM   #1
I have searched through the forums here...can't find answer....
Water pump switch turned on the pump before my trip this weekend. I was hooked up to electric. Unhooked from electric, it still did not work. ??
Battery is good, new. Lights work on battery alone. Everything else works on electric.
appreciate your help
Diane
Diane H is offline   Reply With Quote
Old 06-14-2009, 07:19 PM   #2
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
Check for blown fuse at fuse panel and look for disconnected wires at pump and switch.
Bill K
Diane
Old 06-14-2009, 07:23 PM   #3
Trailer: Fiber Stream
Unhappy
I don't have a Casita, so I don't know if this applies or not...
In my Fiber Stream, the Converter/Charger/110 volt Circuit Breakers/12 volt Fuse Panel is all in one unit.
There are 4 each of the 12 volt DC fuses.
  1. Lights for Bathroom & Kitchen
  2. Lights for Dinette/Bed area
  3. Water Pump
  4. "Furnace" Blower Motor
There are 2 each of the 110 Circuit Breakers
  1. Refrigerator & Microwave
  2. Everything else
My guess is a bad fuse for your water pump, or a bad pump.
Old 06-14-2009, 08:09 PM   #4
Unhappy
There are 4 each of the [b]12 volt DC fuses.
  3. Water Pump
There are 2 each of the [b]110 Circuit Breakers
  2. Everything else
Checked all 4 fuses. They are good.
The water pump was pumping before I left on this trip. Have not gone under the seat yet to check the pump. No access from outside. Will do that next, but not tonight.
Old 06-14-2009, 09:43 PM   #5
Harry Young's Avatar
If you find the switch open after a long store just removing it and reinstalling it will do the trick for another season in many cases.
Harry
Old 09-03-2009, 03:51 PM   #6
Exclamation
sorry for this late reply.....found the problem. The wires had come loose from the
back of the switch (behind the wall of kitchen).
easy fix!
Diane
Old 07-18-2013, 10:29 PM   #7
Trailer: 2011 KZ Sportsmen 242SB / 2004 Ram-Cummins 2500 2wd
Volt meters or at least test lamps are a Godsend. I carry a cheap 'Harbor Freight Tools' digital meter as part of my trailer kit. It's the only easy, non-messy way to check your battery state of charge.
The only thing you have to watch for is that a low meter battery will cause low test readings.
Lloyd (aka Santa) Coltman is offline   Reply With Quote
Old 07-19-2013, 11:20 AM   #8
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Lloyd (aka Santa) Coltman View Post
Volt meters or at least test lamps are a Godsend........
You do realize that you are replying to a 4 year old thread?
Old 07-19-2013, 01:25 PM   #9
Just figured that someone might find it helpful. Hints for the newbies.
Old 07-19-2013, 05:33 PM   #10
Thomas G.'s Avatar
OK, proceed, lots of old posts could use a follow up.
Old 07-19-2013, 07:09 PM   #11
Roy in TO's Avatar
Could be hints for the oldies too.
Adding water pump Jeff Peterson Plumbing | Systems and Fixtures 7 10-08-2009 07:11 PM
Where to mount Water Pump? efawcett Plumbing | Systems and Fixtures 9 07-13-2007 05:10 PM
Electric Water Pump Sharon in AZ Problem Solving | Owners Helping Owners 5 11-03-2006 09:57 PM
Noisy water pump Per Walthinsen Plumbing | Systems and Fixtures 15 06-11-2006 11:30 PM
Fresh water pump Legacy Posts Problem Solving | Owners Helping Owners 10 03-10-2003 06:51 AM
