Water pump problem - broken strainer - Fiberglass RV
Old 09-01-2016, 07:47 AM   #1
I posted a couple of months ago about a leaking fresh water tank in my 2012 Scamp 16. I have finally had time to take a closer look. The strainer is broken off of the pump, so I'm guessing that
a) water can leak out at this point and
b) there would be no vacuum for the pump to work, even if water did not leak out.
I am also guessing that I'll need to replace the entire strainer, which means having to re-seal it. [Edit: The filter cup may just screw on the outside of the unit, so I may not have to replace the entire thing. I did find the aftermarket version, 255-323 on Amazon] They do have instructions on the site: http://shurflo.com/images/files/RV_P...0Strainers.pdf
Rebecca3 is offline   Reply With Quote
Old 09-01-2016, 04:39 PM   #2
Name: Karen & Don
Trailer: 2012 Scamp 13Ft
Rebecca, Karen and I had the same problem with our fresh water filter (strainer). I was able to remove it and took it to an RV dealer in Bangor, and he got me one off of the shelf. It only took a few minutes to replace it.
If you have a lot of cold weather in the winter time, that may be why it cracks. If you are near a RV dealer, they may have the part, or you can get the after market one on Amazon. It's really not too hard to replace.
Kardon is offline   Reply With Quote
Sink Strainer for Scamp 16' Stargazer Problem Solving | Owners Helping Owners 5 07-21-2015 09:33 AM
broken hand water pump cyndi H Problem Solving | Owners Helping Owners 21 10-21-2008 05:58 AM
A Water Pump Problem? Robert Brummett Problem Solving | Owners Helping Owners 2 06-10-2008 05:24 PM
Shurflo Strainer for Water Line efawcett Problem Solving | Owners Helping Owners 8 08-02-2007 04:53 PM
water pump problem Jamey Plumbing | Systems and Fixtures 11 03-07-2007 10:32 PM
» Virginia Campgrounds
