Water Regulator - Page 2 - Fiberglass RV
Old 11-29-2015, 06:45 PM   #15
[QUOTE=Bob Miller;560929
Different camping styles call for different camping styles.....[/QUOTE]
Which is why I pointed out "so many variables!"
But thanks for making my point for me.
Old 11-29-2015, 06:46 PM   #16
Originally Posted by Glenn Baglo View Post
What if the water pressure changes when you're not looking?
The regulator regulates it.
Old 11-29-2015, 06:52 PM   #17
Originally Posted by Bob Miller View Post
... Not only that, you could wind up with a full tank of water when you are ready to leave and have to haul that around or (gasp!) waste it by dumping it. ...
Its so funny to hear from people form California.. where the temps stay temperate but water is scarce.. Around here we don't bat an eye at dumping 10 gallons of water.. heck, even a few 100 on the lawn just to make it pretty is no issue at all.
Actually is you are really hard up for water, then I would actually recommend the on-board tank method. It tends to encourage conservation and prevents the possibility of a ruptured hose which would dump water endlessly until discovered.
Old 11-29-2015, 08:16 PM   #18
But, isn't $12 for a regulator and peace of mind a small price to pay?
Gordon2. You need to read the thread again. I believe you and I are saying the same thing.
Old 11-29-2015, 08:47 PM   #19
The 150 PSI relief valve on water heaters is an emergency pop-off valve that opens only in the event of a run-away overheat. It does nothing to control or regulate pressure, it's not even in the water lines and, if it does open, you will have water all over the place.
If it were the case, every time I turned on the hot water in my RV or my house, the hot water would have higher pressure, but it doesn't.
Old 11-30-2015, 06:06 PM   #20
Dan Meyer's Avatar
The valve on your water heater is a *combination* device. It opens when temperature is too high, or when pressure is too high. You are correct in that is does not control pressure.
The reason the water pressure in your house never gets high when your water heater comes on is two-fold. 1) you are not starting with cold water, so there is less expansion when the water heats up. 2) Your house probably does not have a one-way check valve where the water enters your house. This means that any expansion due to water heating is pushed back into the city water system. If it does have a check valve, you probably have an expansion tank that will limit the pressure rise.
--Dan Meyer
Dan and Dawn's Scamp Travel Trailer
Old 11-30-2015, 06:26 PM   #21
My house has a pressure reduction device between the mains and house plumbing. Just because you can't see it, doesn't mean it's not there.
The RV does not, so a pressure reduction valve is required to protect your plumbing.
Very simple, and less than $12.
Old 11-30-2015, 06:28 PM   #22
There is a backflow preventer on the main lines in most houses to prevent contaminating of the water supply. Mine is right at the output side of the meter.
Old 11-30-2015, 09:47 PM   #23
Trailer: 2013Escape 21
Iowa
I started to hook up at a park last spring when an adjacent camper came over and warned me that the pressure was in excess of 100 psi. I did not hook up. He showed me his Watts adjustable regulator with a gauge on one end. When I returned home I put together a regulator from a picture I took of his regulator. It works well and gives me piece of mind. No blown hoses, no worry about pressure fluxuation, great conversation starter from those with a twinge of concern and no gauge.
Iowa Dave
Iowa Dave is offline   Reply With Quote
Old 12-01-2015, 02:59 AM   #24
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Interesting thread with a lot of comments for the OP to read to the original question although some went a little sideways and have nothing to do with a trailer. Bottom line to the OP is use a regulator when connected to any city water connection.....just cuz, it's cheap insurance. At the hose bib, to protect the hose too, or at the trailer, it will protect the trailers internal water lines/connections.
Old 12-01-2015, 10:04 AM   #25
Trailer: 2016 13Ft Scamp
Thanks Everyone
Just ordered one with a gauge.
EugeneFlorida is offline   Reply With Quote
Old 02-22-2016, 12:52 PM   #26
Dsironi's Avatar
Trailer: 2013 Scamp 16'
Wisconsin
No one mentioned that Scamp has installed a pressure protection within the system to prevent damage from excessive campground water pressure. At least I have understood that my 2013 model had such.
Sironi
Dsironi is offline   Reply With Quote
Old 02-22-2016, 01:01 PM   #27
Sironi
David do you know what model year Scamp started to add them into the system? I know for sure that mine did not have one.
Old 02-22-2016, 01:06 PM   #28
Given that a water pressure regulator is cheap and easy to obtain, and attaches to the faucet, I can't imagine Scamp going to the effort and expense of installing one inline.
I would certainly confirm with Scamp rather than rely on web.
Water pressure regulator Dave Harris Plumbing | Systems and Fixtures 16 08-27-2013 08:54 AM
Propane Regulator Replacement Don Nicodemo Problem Solving | Owners Helping Owners 2 08-06-2006 05:34 PM
water pressure regulator Chris Z Problem Solving | Owners Helping Owners 9 07-05-2006 02:55 PM
Water Pressure Regulator jefh Care and Feeding of Molded Fiberglass Trailers 10 01-31-2006 07:26 PM
Changing LP regulator Legacy Posts Problem Solving | Owners Helping Owners 10 07-02-2003 08:04 PM
