Wax Ring ? - Fiberglass RV
Old 06-18-2015, 06:48 PM   #1
Trailer: 2003 16 ft Scamp
Wax Ring ?
Today I found a partial piece of what looks like a commode wax ring. It had apparently softened (S.GA heat) and fallen directly under the black water
drain on the concrete below the drain.
On inspection underneath, I found some of the waxy material seemingly packed around the black drain as it exits through the flooring plywood.
What is it ? What does it do ? Does it need to be replaced or can I caulk around the black water pipe to protect the hole through the flooring from outside water entering the unit ?
What do I need to do ?
jhornsby is offline   Reply With Quote
Old 06-18-2015, 08:01 PM   #2
The Minimalist's Avatar
Louisiana
If it is indeed a wax ring, there is one, not wax, made specifically for RV's. Last time I checked, Lowe's sells them.
Clif
Old 06-18-2015, 09:23 PM   #3
Scamp places a wax ring under their blackwater tank and the bath floor for a seal it is around the blackwater 3" pipe. No big deal, If the seal is bad when you shower water will come out around the black 3" pipe. Just clean up the mess.
Eddie
2.5 inch retaining ring ... how to remove ... freddo411 Problem Solving | Owners Helping Owners 12 05-08-2012 07:01 AM
"Original" Trillium Factory KEY RING/CHAIN? Dave Baston General Chat 0 06-09-2010 04:53 PM
Wax On... Wax Off... Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 04-19-2003 09:19 AM
Ring in the New Year Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 8 10-22-2002 09:33 AM
