Weatherstripping help needed - Fiberglass RV
Old 07-16-2007, 03:18 PM   #1
Robin H's Avatar
Trailer: 73 13 ft Boler / 2004 Toyota Corolla
Send a message via MSN to Robin H
I think the final thing to figure out is my weather stripping around the door. I bought some foam stuff from home depot - once I put it on, I was unable to close the door - some areas were way too tight and others I could still see outside. Any quick fix suggestions.
I saw some rubber tube type self adhesive stripping at the rv store but it was way too small. Otherwise I looked like it would be perfect. It could squish down for the tight areas and stay expanded for the big spaces.
Anyone have any ideas out there???
Robin
Robin H is offline   Reply With Quote
Old 07-16-2007, 03:29 PM   #2
Trailer: Scamp 16 ft
Robin
try some foam pipe insulation, it comes in 8 ft lengths and is self adhesive.
Dan B is offline   Reply With Quote
Old 07-16-2007, 06:04 PM   #3
Lainey's Avatar
Trailer: 1989 Bigfoot 17 ft and 1989 Li'l Bigfoot 13 ft
If the foam insulation does't work out, maybe hit the auto wrecker for a car door weatherstripping. Mine came off a VW Jetta, but there are probably other ones that could work. I had to cut it down a bit, but it holds on great, and does the job.
Lainey is offline   Reply With Quote
Old 07-16-2007, 06:36 PM   #4
Robin H's Avatar
That sounds like a good idea - did you just use 2 sided tape for adhesive??
Robin
Old 07-16-2007, 06:38 PM   #5
Lainey's Avatar
I didn't need to use any adhesive. There was sort of a metal channel on the inside that I had to pry open to slip it on, and it just needed to be clamped shut a bit here and there with pliers. Very easy.
Old 07-16-2007, 06:57 PM   #6
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Robin, that foam tape is available in different widths and thickness too. How thick n wide you need/want to go depends on your trailer. This is for the door, RIGHT, not the rubber gasket on the body itself????
Old 07-16-2007, 07:46 PM   #7
Robin:
I have a plain, flat RV door on mine, but the frame holding it needs to be removed, shimmed and reset. When that is done I will likely go back to the JC Whitney catalog and check out their selection of rubber molding profiles. I will be looking for the right dimensions in a profile and hopefully a soft, compliant style which will seal well without making it hard to compress and close the door. The idea of using automotive rubber seems like a good one to me.
Old 07-16-2007, 07:52 PM   #8
Alf S.'s Avatar
Hi: The proper (Boler/Scamp) door gasket seal is still being used by Scamp and is avail. from their parts dept. 1 800 346 4962 and ships by mail...Cost $8.00 for the 2pc. set + S/H. Hinge pin sets$5.00 and brass bushings$1.50 also avail!!!
Replace weatherstripping Jane K Problem Solving | Owners Helping Owners 5 09-10-2015 12:48 PM
I DO remove the old foam weatherstripping when replacing with bu Bryan L. Problem Solving | Owners Helping Owners 9 02-16-2009 10:18 PM
RV Appraisal Needed Maureen M. Problem Solving | Owners Helping Owners 18 01-08-2009 05:41 PM
Reflectix needed Bonnie Classified Archives 6 04-17-2008 07:17 PM
no t/v needed steven jones General Chat 3 03-12-2008 09:45 AM
