What glue to use on AC cover? - Fiberglass RV
Old 04-09-2014, 02:30 PM   #1
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
My Ac cover cracked and a plastic piece broke off during the winter.
What type of glue will work on the AC cover.(Made of plastic)
Name:	Sept Oct 043.jpg
Name:	Sept Oct 021.jpg
Old 04-09-2014, 03:15 PM   #2
Brandiwhne's Avatar
Trailer: 1985 Uhaul CT
I like Gorilla super glue
Brandiwhne is offline   Reply With Quote
Old 04-09-2014, 03:24 PM   #3
Here's what you need .
This is not crazyglue, but it binds plastic like crazy. You will need to use a plastic "bridge" inside the joint. I used a flat strip of vinyl cut from a piece of "J" channel for my backer.
The repair is far stronger than the original material alone, and absolutely invisible from the good side. My repair was on the inside control panel cover on my A/C. (same sort of plastic)
It takes 15minutes to hold and 24hrs to cure to full strength.
Old 04-09-2014, 07:00 PM   #4
Goop: They label goop for everything and I think it all the same formula. It sticks and fixes almost anything.
Old 04-09-2014, 07:43 PM   #5
My local body shop had some tool where he could "weld" plastic. He has used it on snowmobile hoods that were some type of plastic, not fiberglass. I repaired a trailer lid that was similar to the old Sears roof top carrier material using fiberglass cloth and resin. Did the same with the swamp cooler cover from our Uhaul. The cloth gives it some extra strength and overlaps the pieces.
Old 04-12-2014, 06:58 PM   #6
Trailer: 1983 scamp 13
If you were closer I could more than likely weld that for you depending on the plastic. Alot of plastic is weldable with the right rods, although it will look "repaired". I have had some luck with melting alike plastic in MEK to make a slurry and using that to glue the plastic pieces back.
firebike is offline   Reply With Quote
What Laminate Flooring did you use? Would you use the same brand again? iplumb Modifications, Alterations and Updates 24 01-14-2012 09:30 AM
Seam tape glue removal Steve Smith Problem Solving | Owners Helping Owners 4 06-27-2009 10:37 PM
How to glue ensolite back on Barry Konkin Problem Solving | Owners Helping Owners 10 02-02-2009 02:59 PM
removing glue colleenz Problem Solving | Owners Helping Owners 11 10-05-2007 08:03 AM
spray glue trouble JIMZ Problem Solving | Owners Helping Owners 7 05-25-2006 10:49 AM
