What is this- on old windows - Fiberglass RV
Old 04-06-2019, 04:59 PM   #1
Joan of Shark's Avatar
Trailer: Companion
What is this rubbery layer that is along the channel where the screws go on these old aluminum windows? I assume it's to help seal the screw holes, but what do I call it to try to replace it. It's a total mess on most of the windows. Either gone or torn up.
If I can't replace it, should I just try to put some sort of gasket under each screw head?
Joan of Shark is offline   Reply With Quote
Old 04-06-2019, 06:33 PM   #2
Trailer: Escape 5.0 TA
Window sealant
Hi Joan, that stuff is butyl putty tape. And it seals the whole window not just the screw holes. It is sold in rolls as tape that is various thicknesses and widths.
starbrightsteve is offline   Reply With Quote
Old 04-06-2019, 06:39 PM   #3
Trailer: Companion
Pretty sure that's not what it is. I have the butyl tape for under the frames, and there is old butyl on the undersides. This has a lot more structure. It's almost like a foam product.
This is on the outer side of the windows.
Old 04-06-2019, 10:34 PM   #4
Patricia D.'s Avatar
Trailer: 1975 Ventura
Hi Joan,
If they are jalousie windows, there is normally a black or white flexible strip that goes into groves on the side of the frame. If that is what you need, you should be able to buy it at an RV parts store. I had no problem locating it. Below is a pic of the frame on my trailer, showing the "track" into which the strip is inserted.
Patricia D. is offline   Reply With Quote
Old 04-07-2019, 05:56 AM   #5
Trailer: Companion
Originally Posted by Patricia D. View Post
Hi Joan,
That is exactly what it is, although these are not jalousie, but you've identified the stuff. Our RV parts store doesn't open till mid May. What should I call it to look on line?
Old 04-07-2019, 06:04 AM   #6
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Its generally called screw cover trim. It comes in various shapes and sizes. Here are some examples:
https://www.all-rite.com/catalog-mai...and-trims.html
Old 04-07-2019, 06:13 AM   #7
Trailer: Companion
Interesting. These seem to cover the entire channel, but this is more of a foam product that the screws are screwed through.
But I'll look at them more carefully.
Old 04-07-2019, 06:25 AM   #8
Trailer: Companion
I believe I'm making this too difficult. I think it's just foam sealing tape.
Foam Sealing Tape
Old 04-07-2019, 09:44 AM   #9
Is it possible that a previous owner could not find the trim so used the foam tape instead?
Old 04-07-2019, 09:57 AM   #10
Trailer: Companion
Patricia- Maybe, but the foam stuff is fine. I found it in gray, so will look better than black, and just bought it.
Old 04-07-2019, 01:07 PM   #11
Trailer: !977 KingsleyGMC, 1968 Bailey Mikado
Nova Scotia
OMG....Joan of Shark....funny ! lol
panhead_mike is offline   Reply With Quote
Old 04-07-2019, 04:06 PM   #12
Name: John & Gloria
Trailer: Bigfoot 21RB
Word of caution (and personal experience) make sure any foam product you buy is not made in China. If it is, it will turn into a sticky mushy mess within a year or two.
Travelin2 is offline   Reply With Quote
Old 04-07-2019, 04:34 PM   #13
Make sure any foam product you buy is not made in the North America. If it is, it will sneak up on you and smother you in your sleep.
Old 04-07-2019, 04:54 PM   #14
Trailer: 2013 Escape 19
Hehr screw cover, can get it from Walmart.com. Now what some prior owner used instead, who knows.
Hehr branded jalousie windows use the Hehr screw covers, about $4 for 8 foot piece.
Old 04-09-2019, 10:56 AM   #15
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Available in Black, Brown, White and Polar White from here:
https://www.amazon.com/AP-Products-0...-fkmrnull&th=1
Also available from here:
http://approducts.net/catalog/index....sort=1a&page=5
Old 04-15-2019, 11:51 AM   #16
Trailer: ECO & Casita
Window seals
I just had my windows pulled, and they used butyl tape to reseal. Mine had 45 year old butyl tape in it, not foam. I got new rubber window seals, that slide into a small track at the top of the window, from Vintage trailer supply. I also added window drip caps above the side windows, that I ordered from them. It looks great, and I hope it will keep my feet dry for another 45 years.
Pat Stipe is offline   Reply With Quote
windows
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Old, old egg 1957 Camilla General Chat 36 09-15-2014 11:59 PM
How old is TOO old for a towing vehicle? Karen Ha. Towing, Hitching, Axles and Running Gear 45 04-14-2014 09:28 PM
Age & Fiberglass. or How old is too old? Pat B Ohio General Chat 16 08-01-2008 08:09 PM
New old owner, or old new owner? drews60 General Chat 7 11-17-2006 05:36 PM
