What Model is my 1975 Trillium - Fiberglass RV
Old 03-03-2015, 04:18 PM   #1
Trailer: 1975 Trillium 1300
I'm new... lol
I keep seeing people toss around model numbers like 1300 and 4500. I have no idea what model my 1975 Trilly is. Help!
PrettylilTrilly is offline   Reply With Quote
Old 03-03-2015, 04:30 PM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Hi Lyndsay, welcome to the site.
The 1300 is a 13' model, and the 4500 is a 15' model. These lengths include the hitch to bumper length.
I have a 1300 in my garage getting rebuilt right now.
Do you have any photos of it?
David Tilston is keeping a registry of all the serial numbers and models, and could likely tell you in a heartbeat if you could supply the serial number.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 03-03-2015, 04:34 PM   #3
Thank you! I have the 15' so a 4500 I can't figure out how to post a pic. I will see if I can figure it out.
Old 03-03-2015, 04:42 PM   #4
Name:	ImageUploadedByFiberglass RV1425422523.953351.jpg
ID:	80931Click image for larger version
Name:	ImageUploadedByFiberglass RV1425422536.719244.jpg
ID:	80932Click image for larger version
Name:	ImageUploadedByFiberglass RV1425422548.419093.jpg
ID:	80933Click image for larger version
Name:	ImageUploadedByFiberglass RV1425422563.935615.jpg
Old 03-03-2015, 04:45 PM   #5
David Tilston's Avatar
Since it is a 1975, it is a 1300, (13'). The 4500, (4500mm) was not made till 1977? Possibly 1976.
The best way to tell is the 4500's have the furnace vent beside the door. Even if a 4500 doesn't have a furnace, there is a flat square, below the belly band, between the wheel and the door.
For pictures, you can see a list of 4500's here:
Serial numbers on a Trillium
And 1300's here:
Just click on the link in the serial numbers for pictures, if available.
Also, you can find a description of the differences in the two models here:
What I like about a Trillium 4500 vs. a 1300
On edit:
Just saw your pictures. Definitely a 1300. I have seen this trailer:
Ab (Canada) - 1978 - Trillium 1300 - $4000
What happened to the front window rock guard? Also, that metal bar under the front window makes me wonder if the inside frame has rotted.
Old 03-03-2015, 04:49 PM   #6
Hrm that's interesting. I don't have all the paper work with me or the serial number at the moment (where would I find it) but the registration said 15' and year as 1975. Will have to measure her when I get her home tomorrow evening.
1300- Awesome thanks
Old 03-03-2015, 04:51 PM   #7
See, told you that Dave guy is a smart fella when it comes to Trilliums.
2017 Escape 5.0 TA
Old 03-03-2015, 04:53 PM   #8
Lyndsay, in my '76 1300, the SN is on the inside of the closet door.
2017 Escape 5.0 TA
Old 03-03-2015, 05:33 PM   #9
I don't remember seeing anything while looking around but again when she's home tomorrow I will have a better look
Old 03-10-2015, 09:22 AM   #10
And 1300's here:
On edit:
Just saw your questions at the end here Dave. The rock guard was blown off in some wind, we have it and will fill the existing holes and then reattach it. It's not the original guard, though most likely the original frame. They have painted/blacked out plexiglass panels. Thinking I may remove the paint and use limo tint or something eels and then paint the trillium flower on it.
As for the metal bar, I have no clue why it's there. And now I'm afraid to look! There's no evidence of leakage around the window and the ensolite looks decent so I am reluctant to peel it back. Anything else I could do to find out?
Lilly The Trilly - 1975 Trillium 1300
Old 03-10-2015, 09:53 AM   #11
I would just leave it till there is a problem.
The material that the rock guard was made of originally is called Filon. Fiber and nylon resin. I have a rather large sheet of flat Filon. I you want to use that for your rock guard.
Old 03-10-2015, 10:32 AM   #12
I've pm'd you about the rock guard
Old 03-10-2015, 11:48 AM   #13
Name:	ImageUploadedByFiberglass RV1426009650.012268.jpg
ID:	81179Click image for larger version
Name:	ImageUploadedByFiberglass RV1426009669.379588.jpg
This is what was in the cupboard not sure what numbers you need or if it was ripped off.
Old 03-10-2015, 01:47 PM   #14
The corner that has your serial number is ripped off. The serial number should be on your registration as well. It will look like this:
13-120xxxx
Where the xxxx is the sequential number of production.
Old 03-29-2015, 07:05 PM   #15
Trailer: 1972 Trillium
Look...............
there is a plate just above the electric plug hide-away to the left of the door. Number should be right there.
AJnK is offline   Reply With Quote
Old 03-29-2015, 07:12 PM   #16
I just looked again.....
and discovered my "plate" is actually a sticker. This may be where they put all of them in those years (mine is a '72). Even though it is glued on it is thick enough that the numbers are stamped in. Mine seems to be one larger sticker where looking at your pics you may have two smaller stickers.
Old 03-29-2015, 07:14 PM   #17
Thanks I will look. I've just been lazy and haven't looked at my registration yet lol
trillium
CA | 1975 Boler Model 1300 Project $500 JCusick Classified Archives 13 06-21-2013 12:57 PM
1981 Trillium 4500 - Rare Double Dinette Model Booker B. Classified Archives 5 04-16-2009 09:49 AM
Looking for a web video of small model car towing a small model traile ronsmith100 General Chat 3 02-14-2009 08:02 PM
