What signs that a gas regulator needs changing? - Fiberglass RV
Old 04-17-2009, 05:53 PM   #1
TonyB's Avatar
Trailer: Bigfoot 19 ft (B19)
What is the average lifespan of a gas regulator? I thought that I needed to change mine as the lever to select the service cylinder seized up but a squirt of WD40 got it moving again. I did a search for Marshal 250 (the regulator) and was surprised to see accounts of these failing after only months of operation. Also a recall of some batches. It could be that some older ones are better built than the newer ones.
TonyB is offline   Reply With Quote
Old 04-17-2009, 06:47 PM   #2
Pete Dumbleton's Avatar
I wouldn't use WD-40 in a situation like that -- It's not a lube and it leaves behind a 'protective coating' that may gum up the works on a mechanical system.
You can build your own manometer to test and adjust the output pressure of the regulator:
http://www.rverscorner.com/manometer.html
Or you can just replace the regulator -- A two-stage LP regulator goes for about $20.
propane
Signs of Humor Frederick L. Simson Jokes, Stories & Tall Tales 5 09-12-2006 05:19 AM
Signs of the times Legacy Posts Jokes, Stories & Tall Tales 15 07-20-2003 08:57 PM
Changing LP regulator Legacy Posts Problem Solving | Owners Helping Owners 10 07-02-2003 08:04 PM
Store Signs Legacy Posts Jokes, Stories & Tall Tales 1 03-03-2003 04:27 PM
Signs You Might Be Too Canadian! Legacy Posts Jokes, Stories & Tall Tales 30 11-10-2002 11:38 AM
