What size ball on the hitch - Fiberglass RV
Old 08-20-2019, 09:42 AM   #1
Trailer: Bigfoot 17G
Does anyone know an easy and foolproof way to physically determine what size ball is required to safely hook up with a particular hitch?
bobblangley is offline   Reply With Quote
Old 08-20-2019, 10:42 AM   #2
Trailer: 1999 Casita 17' SD
Ohio
Look carefully, it may be stamped into the hitch along with max weight and so forth.
But if it's got a lot of paint it might not be visible.
But I do know a 2" ball won't fit into an 1 7/8" hitch.
There's a chart here showing the maximum for each size ball.
https://www.westmarine.com/WestAdvis...s-and-Couplers
Old 08-20-2019, 11:52 AM   #3
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
If you can't find any markings on the coupler, a bit of trial and error is required, along with an educated guess.
1 7/8" are old fashioned and only for the lightest of trailers. A 2" ball will not fit a 1 7/8" coupler.
2" is overwhelmingly used in almost all applications below about 10,000 lb trailers, and certainly below about 7,000 lb trailers.
2 5/16" are used on goosenecks and heavy utility trailers heavier thatn the above numbers.
If you are unsure what you have (your Bigfoot is going to be a 2"), get a 2" ball and try it in the coupler you are unsure about. If it won't fit, and the trailer is small and light and older, you need a 1 7/8". If the 2" rattles around in the closed coupler, and the trailer is a heavy dump trailer, then you need a 2 5/16" to fit properly. Trial and error.
Be sure to match the ball shank size to your tow bar hole size. Some are only 7/8" threaded shanks and should not be used with 1 1/4" tow bar holes. I always use a 1 1/4" shank and tow bar if possible. Look on top of the ball for it's rated load capacity and get the highest you can fit to your TV. The tow bar hole will determine this. The rated load stamped on a given ball should be the same or greater than your trailer's gross weight rating.
If you think you are getting close to what a 2" ball can handle, around 7,000 lbs, you can upgrade to a 2 5/16" coupler and ball. This will push the rated load capacity of that combination to about 14,000 lbs. This is kind of meaningless unless you have a type 4 or type 5 hitch and a rated draw bar to match.
Raspy is online now   Reply With Quote
Old 08-21-2019, 09:15 AM   #4
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
By trial and error. As others have said, most trailers use a 2" ball.
Some hitch sockets are adjustable. The ball should fit snugly so it doesn't have any looseness.
Old 08-21-2019, 01:44 PM   #5
My newer Bigfoot 17.5 uses a 2-5/16” ball, and it’s much less than 7000lbs.
SnowballCamper is offline   Reply With Quote
Old 08-21-2019, 03:06 PM   #6
Raspy's Avatar
Originally Posted by SnowballCamper View Post
My newer Bigfoot 17.5 uses a 2-5/16 ball, and its much less than 7000lbs.
There is nothing wrong with going bigger on the ball size if one chooses to, but it's optional, not required, unless the trailer weighs more than the ball is rated for. I went to 2 5/16" on my Oliver and it only weighs 5,700 lbs. It came with a 2" ball rated for 7,000 lbs.
I like 2 5/16", plus I have other trailers that are heavier and it was easy to standardize. Stronger is better.
Old 08-21-2019, 03:17 PM   #7
John in Santa Cruz's Avatar
Mid Left Coast
1-7/8 is used quite a lot on light boat trailers, hobie's, FJ's, light utility trailers, etc. all class I/II stuff.
Old 08-21-2019, 03:21 PM   #8
Trailer: Eco
Kansas
I wonder how many older eggs are still using a 1 7/8 too. Mine is, but if I ever replace the coupler I'd change it out to a 2".
My '71 Eco Restoration Gallery
Baxter is offline   Reply With Quote
Old 08-21-2019, 11:16 PM   #9
Mid Left Coast
When i was towing light trailers with a class I/II on my various cars, I was using those changable balls that had both a 1-7/8" and a 2" ball that fit on the same post. I'd never use of those towing our fiberglass things.
On that topic, I was pleasantly surprised how well my 87 Volvo 240 sedan, and '92 Volvo 740 wagon towed a < 2000 lb utility trailer. Sure, I stayed out of OD/4th on the automatics, and therefore the gas mileage was pretty bad, and it did require me to lean on the turbo pretty hard going up grades on the 740 (and just downshift to 2nd on the 240 and take it slow), but the chassis and suspension handled it without any drama. Those RWD live axle 4 cyl cars were rated for a 3500 lb trailer and 1000 (sedan) or 1200 (wagon) payload.
Old 08-22-2019, 11:44 PM   #10
Trailer: Escape 21 'on order'
2" balls
The factory said to be sure to grease your balls
Fred762 is offline   Reply With Quote
Old 08-31-2019, 03:11 AM   #11
Trailer: 2017 19' Escape
Everywhere
They probably just standardized on one size ball for all models for simplicity. So, overkill for the 17.5 but about right for the 25' models.
Old 08-31-2019, 10:06 AM   #12
Trailer: Park Liner
GA
Okay, now I am really confused.
I have purchased a Frontier Pro4X and a 2013 PL, and I had a Class III trailer hitch receiver installed on the truck. It has a 2" square "hole" to slide the hitch into.
Now, I need to figure out how long of a hitch and what size hitch ball to get. I am guessing this 2013 PL coupler is the original.
Is there anybody out there who has a 2013 PL that can tell me what I should be looking to buy? I have never owned a travel trailer, or a pickup so I am in deep waters here. I wanted to be on the road by now but finding a truck that could do the job and not be too big/tall and within price range has been a challenge. I settled on a 2018 Frontier Pro4x.
Thank you,
Tinkerbelle
Tinkerbelle is offline   Reply With Quote
Old 08-31-2019, 02:12 PM   #13
Mid Left Coast
the hitch on the trailer should have the size stamped into it. its probably 2"
with the trailer parked on level ground and leveled, measure the height of the trailer hitch, and measure how far from the ground to the top of the 2" square reciever on the truck. you'll want a tow bar with sufficient drop (or rise) so the trailer rides approximately level when being towed. if the tailgate of the truck is particularlly tall (like my f250 superduty), it might not open without hitting the tongue jack on the trailer, so then you'd want a longer towbar so you can get into the back of teh truck when hitched.
two random towbars I used with my Tacoma 4x4 to pull a Casita. the bottom one has a little more drop and caused that trailer to ride more level, but was shorter and had some tailgate interference.
Old 08-31-2019, 02:18 PM   #14
John in Michigan's Avatar
EDIT: the hitch on the trailer should have the BALL/COUPLER size stamped into it. its probably 2"
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
HELP! At trailer hitch place, what size ball do I need? joy mccalla Towing, Hitching, Axles and Running Gear 5 01-18-2010 09:48 PM
Wrong size hitch ball Kevin K General Chat 10 06-23-2009 04:09 AM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 04:05 PM
TRAILER BALL SIZE ??? Dan Quinn Problem Solving | Owners Helping Owners 2 06-07-2006 01:50 PM
Ball Hitch size for '82 Burro Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 08-15-2003 09:39 AM
