Back when I had 14 inch rims and wanted load range D
tires, I seem to remember the Kumho being the only brand I could find in a 14 inch load range D radial trailer tire. Those I could find only on line at Tire Rack, and they were out of stock. I switched to 15 inch rims so I could have a load range D radial for which replacements could be easily found while traveling. I started with 205/75R15, which became hard to find. Then I switched to 225/75R15 ( Goodyear Marathon), which fit in the wheel well of my axle-flipped
Bigfoot 17. That heavy beast pulled so much better after the switch. The trailer sways less and the passing big trucks do not push me around nearly so much anymore. In my travels I have seen a few Casitas with the 225/75R15 load range D Marathons, so they will fit, perhaps with some lift..
