What to put on small hole -outer portion of fiberglass - Fiberglass RV
Old 11-19-2015, 12:06 PM   #1
Northern California
There is a small hole/crack on the outer portion (gel coat?) just above the belly band of our scamp.I am curious what kind of goop/ sealant to put on it? I have some 3m 4200, some dap lap sealant some other caulk as well as quick fix for surfboard ding repair ( a mix of fiberglass and resin). Any suggestions on what to use? The hole is about a quarter inch thick and the whole star fracture of the outer coating is about an inch
HAPPYSCAMPER76 is offline   Reply With Quote
Old 11-19-2015, 01:55 PM   #2
Trailer: 1993 CASITA 16SD
I like white JB Weld.
CASITA BANANA is offline   Reply With Quote
Old 11-19-2015, 02:01 PM   #3
Borrego Dave's Avatar
How about giving us a pic ?
Old 11-19-2015, 10:27 PM   #4
Northern California
Here are some Photos
Here are some photos. Any additional suggestions are much appreciated. The white stuff on top of the bellyband is just older caulk
Bryan
Old 11-21-2015, 07:17 AM   #5
Trailer: 1997 16' Scamp
It looks like you just have some gelcoat chipped away. I'm guessing there is no structural weakness or cracking that extends behind the belly band.
I think the white JB Weld suggested is the simplest fix.
Remove any loose gelcoat with a dremel or a bit of sandpaper, wash with acetone and tape the area off to leave a pleasant geometric pattern. The stuff will not match perfectly and an irregular splotch jumps out more than a nice triangle or shape you choose.
If your really fussy you can buy white gelcoat which will not match perfectly either but it will wet sand, buff out and blend a bit better.
varmint is offline   Reply With Quote
Old 11-21-2015, 11:29 AM   #6
Raz
Raz's Avatar
I'm a fan of PC-11 epoxy paste but I suspect the JB Weld would work just as well. West Marine sells a gelcoat repair kit if that's a direction you'd rather go. I've never tried it but have read that getting the color to match is challenging. Raz
WEST MARINE Gelcoat Repair Kit | West Marine
Old 11-23-2015, 01:41 AM   #7
Denece's Avatar
Trailer: Compact II
I have used the West Marine gel coat repair. It makes a nice cosmetic fix for dings. Make sure the color matches!
Denece is offline   Reply With Quote
Any reason I can't just buy small elec. fridge and put in Compact Pat Goodwin Problem Solving | Owners Helping Owners 26 11-01-2017 05:25 AM
How to make a small precise rectangular hole? frank_a Problem Solving | Owners Helping Owners 12 08-02-2014 08:40 AM
Old man winter put a hole in by Boler nelsons Care and Feeding of Molded Fiberglass Trailers 22 05-11-2014 10:13 AM
Anyone put a small fridge where bunk cushions go? Gretchen Problem Solving | Owners Helping Owners 3 02-04-2014 07:27 AM
17' Casita on Outer Banks Chesley Sugg Classified Archives 2 11-16-2010 11:44 AM
