What To Use to Remove Old Decals - Fiberglass RV
Old 08-20-2014, 09:42 PM   #1
Trailer: 1990 16 ft Casita DLX #6
What do you use to remove old decals from fiberglass?
Losthwy is offline   Reply With Quote
Old 08-20-2014, 10:01 PM   #2
Trailer: Bigfoot 17' DLX
Alaska
A heat gun and a plastic scraper/putty knife for most. For the ones that are completely cracked and brittle, this may not work. For that I use a 3M™ Stripe Off Wheel. You can read more about those in this thread...
15 minutes with a 3Mô Stripe Off Wheel - Bigfoot
trainjunkie is offline   Reply With Quote
Old 08-20-2014, 10:24 PM   #3
IllAnnoy
The heat gun and plastic scraper will work great... but this is one case where a hair dryer may be the better choice, and even then careful with the heat.
Just enough to soften the vinyl and the glue being careful not to start to soften the gelcoat
Scrubbing the cold residue with ordinary hand cleaner, softscrub, or a heavy solution of carwash soap and scotchbrite.
Follow this with a good coat of wax and gelgloss.
The results will likely be very nice until the sun shines JUUSST right on it and you can still see faint evidence of the decal, because the decal had protected the gelcoat under it for the last 24 years.
Old 08-20-2014, 10:59 PM   #4
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Originally Posted by trainjunkie View Post
A heat gun and a plastic scraper/putty knife for most. For the ones that are completely cracked and brittle, this may not work. For that I use a 3Mô Stripe Off Wheel. You can read more about those in this thread...
Amen to that, but I used a cheaper imitation and it also worked great. On the door it took the paint off, though, but on the gel coat it just took off the decal.
Old 08-21-2014, 12:10 AM   #5
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I used the 3m wheel. It went pretty fast. I don't think it took over 4 hours to strip them all. I finished up with scotch brite and barkeepers friend.
Name:	ImageUploadedByFiberglass RV1408601244.197809.jpg
Name:	ImageUploadedByFiberglass RV1408601281.099751.jpg
Name:	ImageUploadedByFiberglass RV1408601312.399177.jpg
The gelcoat was high under the decals, so I block sanded it when I was done. You can still see the outline, but not easily.
Old 08-21-2014, 07:06 PM   #6
I use a hair dryer believing the heat gun to be too hot. To get the old stubborn glue, goo-gone or WD-40 works great. I've used acetone on occasion for the last really stubborn stuff but always sparingly and then rinse any residue off. Wear chemical proof gloves and consider a proper chem mask. Nasty stuff! This worked great for removing all the old decals and the lateral stripe from our old Trillium. How to handle the decal "shadow"? New decals, new stripe! Oh and I finally applied Zep this year - looks brand new!
Randy J. is offline   Reply With Quote
Old 08-21-2014, 07:33 PM   #7
That shiny stuff after the decals are removed, is just telling you how aged your trailer is. Scuff it up, apply new decals.. wax or ZEP... then go camping! It's NOT about how "new and fancy" your trailer is... it's about the MEMORIES!
Old 08-21-2014, 07:34 PM   #8
Trailer: 77 Scamp 13
+1 on just put new decals over old decal shadows. And the 3M stripe off wheel worked fantastic for me. Thing is sold in auto paint shops for body shops. It's essentially an eraser on a shaft. Run it in a variable speed drill. Cleans the decals off really fast.
Would caution you to make sure trailer surface is clean and not get dirt on the wheel. Dirt on trailer or stripe off wheel will leave scratches.
Old 08-21-2014, 08:48 PM   #9
Perfect Roger. I've read, over the years, folks that have removed decade-old decals quickly with the "eraser." I'm just grateful the ones on my 26 y/o Scamp are in good shape!
Old 08-21-2014, 09:01 PM   #10
Thanks for the info. I tried some decal remover and white gas. Both took off the blue but not the film under it. I'll try the hair dryer.
Old 08-22-2014, 05:49 AM   #11
Jared J's Avatar
Kansas
The wheel pulled my 30 year old ones off with ease.
Block sanding the gelcoat profile left behind took a lot longer.
UHaul Decals - Remove overlay? Thomas G. Modifications, Alterations and Updates 27 03-19-2012 06:11 PM
How to Remove Olddd Decals... Harvey Problem Solving | Owners Helping Owners 7 11-05-2011 02:12 PM
How do you remove decals/graphics? Bill Drummond Problem Solving | Owners Helping Owners 4 01-29-2009 08:37 AM
Best way to Remove Old Body Decals? Kevin A Problem Solving | Owners Helping Owners 4 04-17-2007 07:05 PM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
» Trailer Showcase
Big Ei
Lora
Ventura
csgauthier
