What's behind door number one? (Backsplash) - Fiberglass RV
Old 04-02-2015, 11:15 PM   #1
Trailer: 1975 Trillium 1300
I willy nilly went and got lost in Ikea and saw and subsequently bought these
Name:   ImageUploadedByFiberglass RV1428037929.945392.jpg
Now I'm faced with a dilemma. Can anyone tell me if there are studs or anything to attach to behind the backsplash of a 1975 trillium 1300?
Name:	ImageUploadedByFiberglass RV1428038004.610898.jpg
If not, do you think it would hold the weight of these with kitchen stuffs (utensils and soap and condiments) in them? Maybe about 10lbs or so of things? Also any other ideas for attaching them would help!
Thanks for the help
Lilly The Trilly - 1975 Trillium 1300
PrettylilTrilly is offline   Reply With Quote
Old 04-02-2015, 11:20 PM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
No studs, but you could rivet to the gallery fiberglass.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-02-2015, 11:22 PM   #3
It would be difficult to rivet this bar in place. Actually impossible I think.
Old 04-02-2015, 11:27 PM   #4
Why is that? If it uses screws, just substitute with rivets.
Command brand adhesive strips hold a pretty good weight, but not sure about sticking them to the adhesive tile you have though.
2017 Escape 5.0 TA
Old 04-03-2015, 09:25 AM   #5
Trailer: 1978 Trillium 4500
Lyndsay, I used the 3m adhesive velcro designed for hanging heavy pictures. So far, no problem. They can hold quite a weight and come in black and white.
Island Claire is offline   Reply With Quote
Old 04-03-2015, 09:36 AM   #6
A picture may explain better than I do.
Name:	ImageUploadedByFiberglass RV1428075288.017414.jpg
ID:	82192Click image for larger version
Name:	ImageUploadedByFiberglass RV1428075316.300889.jpg
Once the inner plate is attached to the bracket I don't know how I would rivet it to the fiberglass
Old 04-03-2015, 09:37 AM   #7
I looked at industrial strength Velcro but it's a small area that it would go on and I don't know that it would hold. What sort of bracket did you use it on?
Old 04-03-2015, 09:55 AM   #8
BAMA & Pachyderm Posse's Avatar
Arkansas
a bowling ball to the side of a trailer at 100 m.p.h
This stuff will darn near hold a bowling ball to the side of a trailer at 100 m.p.h . lol click on this link 3M Double Sided Tape, 3M Double Sided Adhesive Tape in Stock - Uline
HERSCHEL AKA BAMA
BAMA & Pachyderm Posse is offline   Reply With Quote
Old 04-03-2015, 10:05 AM   #9
Here are some pictures. The upside down one came un-velcroed when we were traveling with two tea towels hanging on it and hit a good bump. I am going to move it to the wall this spring. The one above the utensils was actually an over-the-door bar and we cut off the hook part.
When we bought the trailer the previous owner had glued a piece of wood (circular) on a plastic towel rack and then onto the fiberglass. We were able to remove it with much difficulty and had to hide what we could not get off so we installed a new rod where the old marks were.
Old 04-03-2015, 10:09 AM   #10
Thanks for the ideas everyone. I'm going to try a few different things and see what works.
Old 04-03-2015, 10:12 AM   #11
sarahspins's Avatar
Trailer: 1984 13' Scamp named "Ramblin Rose"
Washers Just pick something big enough not to slip through the slot that the rivets will fit through.
sarahspins is offline   Reply With Quote
Old 04-03-2015, 03:21 PM   #12
Attachment 82192Attachment 82193
I see. They have this same bar with a mount that uses screws that remain visible. This is what I was thinking you would use, as rivets would work fine with them.
2017 Escape 5.0 TA
Old 04-03-2015, 03:23 PM   #13
Name:	ImageUploadedByFiberglass RV1428096175.294688.jpg
I jumped and just did it. We will see if it lasts lol.
Old 04-06-2015, 06:59 PM   #14
gailanneM's Avatar
Trailer: Bigfoot 25' and previously, 17' Burro
IKEA kitchen upgrade
That looks marvelous!! I love that ikea system & put one in my Burro -- your backsplash is fabulous!! ;-)
gailanneM is offline   Reply With Quote
Old 04-06-2015, 07:00 PM   #15
Thank you
Old 04-06-2015, 08:12 PM   #16
Trailer: 2010 Escape 17B
That looks so cute, love it.
kootenaigirl is offline   Reply With Quote
Old 04-06-2015, 08:24 PM   #17
Looks great. If what ever you used to hold it does not work out you could always mount it using nuts and bolts through the fiberglass in the over head cabinet.
Old 04-07-2015, 08:09 AM   #18
We had thought about doing that and then using chain the hang the second one down lower. We have backup plans lol
Old 04-07-2015, 10:08 AM   #19
David Tilston's Avatar
The green stove look great!
Old 04-07-2015, 11:36 AM   #20
Matches perfectly eh?! Just had a friend clean it up for me. Will be putting it in for show for now until I have the time and weather to plumb it properly.
Parkliner - Storage behind Door Huck Modifications, Alterations and Updates 7 05-10-2014 05:24 PM
Scamp 19 anyone modified to tow behind an SUV? Wayne Hill Towing, Hitching, Axles and Running Gear 23 04-13-2011 08:47 AM
Would the last one behind next weekend, turn out the light? CindyL General Chat 11 09-24-2010 09:43 AM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 04:05 PM
fishing wires behind Scamp's ceiling carpet Legacy Posts Electrical | Charging, Systems, Solar and Generators 6 07-11-2003 10:18 AM
