What's the purpose of this tab? - Fiberglass RV
Old 07-03-2013, 11:30 AM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
On 1999 17' Casita SD
Old 07-03-2013, 12:44 PM   #2
LeonardS's Avatar
Trailer: not yet
Maybe to support a tray? The tab looks level with the bar to the left. A triangle piece of decking (wood? mesh?) could possibly fit there.
Honestly, just a guess.
LeonardS is offline   Reply With Quote
Old 07-03-2013, 12:51 PM   #3
I think thats aq good guess.
Are there any other tabbs?
RRJR is offline   Reply With Quote
Old 07-03-2013, 01:11 PM   #4
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
No other tabs, just that one.
Old 07-03-2013, 02:15 PM   #5
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
That tab it there to hold the anthelator that attaches to the muffler bearing that goes to the gizmo for the harmonic stabilizer for the front window!
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 07-03-2013, 04:26 PM   #6
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
As long as we're on the subject:
What's the purpose of that OTHER black tab on the framerail (upper left of the pic-frame just behind the shiny hardware )?
Not that it prolly matters...just wondering!
Francesca
Old 07-03-2013, 05:07 PM   #7
cpaharley2008's Avatar
It appears that metal tab maybe protection for your tank valve behind it, can not tell if it is vertical or horizontal?? If horizontal then perhaps there was another one on the other side and some sort of holder fit inside that space.
Jim
Never in doubt, often wrong
Old 07-04-2013, 05:42 AM   #8
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Name:	june 17 2013 073.jpg
Only 1 unknown tab in front of propane tank.
The other tab holds 2 propane tanks in place. ( I only use 1 tank)
This has me stumped.
Old 07-04-2013, 06:16 AM   #9
WAG #3 Ahaa.... I'll bet at one time, when there were two lp tanks being used, that the tab was part of the center tie down for the two tanks.
Old 07-04-2013, 07:14 AM   #10
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
That's what I thought also. But the tab is NOT in the center. The 1 propane tank I have now is centered.
VERY INTERESTING ?????????????????
Old 07-04-2013, 07:33 AM   #11
Did you look on the opposite side to see if there was any evidence of a matching tab having broken off and even been repainted over?
Old 07-04-2013, 07:40 AM   #12
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Yes, no signs of a tab.
Old 07-04-2013, 06:29 PM   #13
Saskatchewan
Theory, given that your tank valve is there, and there was the option for a second tank, it's possibly that the tanks were secured independently, minimizing the need for extra fabrication and extra parts that may not be used and cost more.
So instead they could flip the mounting points around, mirroring the sides and only using one part that is already in stock, also allowing for the removal of the second tank with out disturbing the other tank to gain access to that dump valve.
Orcus79 is offline   Reply With Quote
Old 07-05-2013, 12:34 PM   #14
Roy in TO's Avatar
Is there an option for a box or cover on the tongue? It might explain both tabs.
Multi Purpose Bilge Tubing D Davis Problem Solving | Owners Helping Owners 0 04-13-2012 06:04 PM
What is the purpose of internal battery connections? jordo Problem Solving | Owners Helping Owners 10 10-17-2011 04:57 PM
Multi-purpose Room Ed D General Chat 2 01-10-2010 07:47 AM
All purpose table Legacy Posts Problem Solving | Owners Helping Owners 8 01-26-2003 01:51 PM
