Wheel bearing question - Fiberglass RV
Old 03-12-2012, 01:05 PM   #1
Denece's Avatar
Trailer: Compact II
We are up to ding the wheel bearings on our to-do list. The current bearings are good on one side and leaking on the other so we are trying to replace them.
Our question:
A; the ones we took out are marked KOYO HI-CAP JAPAN L44643R
We can't find any replacements with the R.
B; one of the caps has a 1/16 inch hole drilled in it, like maybe someone was going to install a zirc fitting. Should we replace that as well? (it's on the leaky side)
I know this will be a stupid question to somebody out there!
Thanks in advance for answering anyway!
Denece is offline   Reply With Quote
Old 03-12-2012, 01:33 PM   #2
Trailer: scamp 13
not sure what your asking,,,is it the seal your replacing?
Old 03-12-2012, 01:48 PM   #3
Take one complete set of bearings and seal from one side of the axle along with you to tractor supply and have them match them up to the new ones you need.
Timken Bearing L44643 L44610-Timken Bearing L44643 L44610 Manufacturers, Suppliers and Exporters on Alibaba.com
Old 03-12-2012, 02:31 PM   #4
Denece's Avatar
Trailer: Compact II
Seal and bearings both. Not sure where we'd find a tractor supply around here. We can take it around to the auto parts houses.
Is the R an important part of the designation ? We can find the same number on the website but it doesn't have an R
Thanks
Old 03-12-2012, 02:48 PM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Trailer bearings and seals are pretty standardized, the R is not critical. You can check with an RV dealer, or find a local trailer fabrication shop. Many sell standard parts on the side. You might even find the parts at a big box store like Walmart in the RV section.
http://www.etrailer.com/dept-pg-Trai...and_Races.aspx
Old 03-12-2012, 03:39 PM   #6
I get my bearings at an auto parts store. the inner seals can be tricky sometimes as far as the outer diameter measurement. Take it with you to the parts store, see if there is a number on it. That outer measurement can be different by very little sometimes. Replace the cap or plug the hole somehow. If you're greasing the old ones, clean them good, I have a small parts washer, or I use gasoline [probably get comments on that!!] If you blow the bearings with air, DO NOT let them spin at high speed, they can fly apart. To grease the bearings, put a blob of bearing grease in the palm of your hand, I use the red stuff. Then press the edge of the bearing into the grease, working all around the circumference, and force grease up through the bearing. I always put grease in the hub, around the inside of it. Don't overtighten the nut, and use a new cotter pin. Bob
Old 03-12-2012, 03:50 PM   #7
Denece's Avatar
Trailer: Compact II
He's having to do research on the seal, but it was no problem to find bearings at our local parts emporeum. Hopefully he'll find a seal. We got nice new shiny caps while we were at it.
Apparently the R is not important unless you want Pirate bearings (that's a joke)
Really hope the seal is findable since the number on it didn't ring any bells in the auto parts computer.
Old 03-12-2012, 03:53 PM   #8
Thomas G.'s Avatar
The seals are standardized just like the bearings. Check out the eTrailer link I posted above.
Old 03-12-2012, 04:17 PM   #9
I'll have to slightly disagree with Thomas, MOST seals are standardized, but one of my trailers wouldn't take a standard seal. Fortunately I have an independent parts store here where the parts guys know how to measure a seal and look up the numbers in a book, not on the computer. I had to get a seal that was about .010" smaller outside diameter to fit in the hub. This is a rare circumstance, so you shouldn't have this problem. There's real partsmen, and those that just look on the computer and if the answer doesn't pop up they can't help.
Old 03-12-2012, 04:19 PM   #10
Thomas G.'s Avatar
Originally Posted by mary and bob View Post
I'll have to slightly disagree with Thomas, ..........
Good catch!
Now you were kidding about using gasoline for parts washing when fuel oil is so much safer and works just as well.
Old 03-12-2012, 04:45 PM   #11
Trailer: U Hall VT
Smile
How come no one has mentioned anything about smoking, Duh
Roger Kimble is offline   Reply With Quote
Old 03-12-2012, 05:00 PM   #12
Raz
Raz's Avatar
Vermont
Gasoline was recommended to me because it's a good solvent and if you let the bearing sit for few minutes after cleaning, the gas will vaporize and not effect the new grease.
Old 03-12-2012, 05:50 PM   #13
Trailer: U Hall VT
Smile
It will, but fuel oil or kerosene is safer, just takes a little longer.
Old 03-12-2012, 06:00 PM   #14
Thomas G.'s Avatar
It's that same volatility that allows the vapors to be ignited by static electricity.
Wheel bearing info Rick Harmer Towing, Hitching, Axles and Running Gear 7 05-20-2010 08:08 AM
Problem With Wheel Bearing Randy Bishop Towing, Hitching, Axles and Running Gear 3 06-16-2008 07:21 PM
Wheel Bearing Check Anders Laurits General Chat 7 12-16-2007 09:05 PM
Problem With Wheel Bearing Randy Bishop General Chat 0 01-01-1970 12:00 AM
