I tried removing a wheel from my 1984
Scamp 13' trailer for the first time and failed. The trailer sits quite low and I suspect the
tires are larger than stock. After jacking up and blocking both sides significantly to get plenty of ground clearance, the wheel kept getting wedged between the wheel well and the end of the
axle. Clearly I'm missing something; the guys at the tire shop didn't mention any trouble the two times they've worked on it. Suggestions?
On the other hand, I'm glad I discovered this before figuring it out the hard way on the side of the freeway while trying to change a tire :/
