wheel well repair - Fiberglass RV
Old 05-22-2009, 03:03 PM   #1
Trailer: 1998 17 ft Burro (aka Frankeggstein's Monster)
Dh plans to sand the rough edges and patch with a fiberglass kit, do you think that will work? It seems to be caused by water damage, the camper had water damage elsewhere and the problem has been rectified.
If you can't tell from the pics, there is rot & separation where the belly pan & well meet to varying degrees.
roadside
curbside
There appears to have been a big patch here on the curbside and I have no idea what they patched it with.
Kelly G is offline   Reply With Quote
Old 05-22-2009, 07:20 PM   #2
kevin61's Avatar
Trailer: 13 ft Boler and 17 ft Boler
I am not familiar with the construction of a Burro but if it is just fibreglass I would cut out all the "rot" and patch with fibrecloth and resin. If it has gelcoat you will have to grind it down to bare fibreglass to get the new fibreglass to stick. A few layers for strength and then some bondo to smooth it out and it should work OK.
kevin61 is offline   Reply With Quote
Four Wheel Drive versus Two Wheel with Posi Rear End Lyndon Laney Towing, Hitching, Axles and Running Gear 8 04-16-2010 09:38 PM
Scamp Trailer Crank Wheel/No Wheel Mitchell Problem Solving | Owners Helping Owners 6 08-25-2008 11:36 AM
On the road repair R&SGove Problem Solving | Owners Helping Owners 0 07-16-2007 07:27 AM
Fiberglass Repair mwinslow Problem Solving | Owners Helping Owners 4 11-18-2006 08:12 AM
Fiberglass Repair nrsmd Modifications, Alterations and Updates 7 12-18-2005 06:33 PM
