Where are the body/frame attachments on a Scamp? - Fiberglass RV
Old 03-23-2019, 01:24 PM   #1
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
I am wanting to take the body off the frame and have located most of the screws but want to know if there are any bolts anywhere. I can't get it to separate right back where the shell and the frame/rear bumper stays are. Is there a bolt there or something? I've run a blade in between the body and frame and I seem to run into something but can't cut through it. It's a very tight area so I am running out of room. I also can't see a bolt head inside the trailer but this is also where the shell gets glassed to the plywood and it's a bit clumpy and bumpy. In all of these FGRV posts no one has ever said exactly where all these attachments points are on a Scamp! Thank you.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 03-24-2019, 12:25 PM   #2
Trailer: Triiiium 13'
I Did a complete body off retro on my 13' Scamp. On mine there were about six screws running along the frame. No bolts at all.
Martin.P is offline   Reply With Quote
Old 03-24-2019, 02:01 PM   #3
Bryan L.'s Avatar
Ha, 6 screws! That seems ridiculous. I guess it works though. Thank you for the reply.
I'll probably add a couple brackets and do two bolts up front and two in back on addition to the screws when it goes back together but I guess I'll need to use a bit more persuasion on that end section then.
Old 03-24-2019, 02:08 PM   #4
When I put it back together. I used 4 U,bolts around the frame. Plus more screws.
Old 03-24-2019, 03:15 PM   #5
Borrego Dave's Avatar
Weld some angle iron to the side rail of the frame for the bolts.
Attachments R&SGove Forum Admin, News & Announcements 4 05-31-2008 08:13 AM
Size Limit for Attachments Mary F Forum Admin, News & Announcements 3 02-20-2006 02:03 PM
Photo & file attachments Charlie C Forum Admin, News & Announcements 2 11-26-2005 01:06 AM
Attachments R&SGove General Chat 0 01-01-1970 12:00 AM
