Where do I buy Melamine Paint???????? - Page 2 - Fiberglass RV
Old 04-10-2011, 04:35 PM   #15
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
Opps, sorry Donna, I was busy ripping out pipes that shouldn't be (ripped out!)
That sounds promising-----says it's for indoors, etc. Do you think "low-luster" means it's NOT shiny?
I'll call a Benjamin Moore dealer tomorrow.
Thanks! (Sure wish my cabinets didn't need to be painted!) Hey--anybody out there know how to fill holes (screws, nails, etc.) and touch up--so it looks nice without having to paint everything?????
Vickie B. is offline   Reply With Quote
Old 04-10-2011, 04:47 PM   #16
I've never used Melamine paint Vickie. I was just trying to help you find a dealer of the paint in the USA. It's possible your local Benjamin Moore dealer can either order the kind/gloss out of Canada or tell you precisely the USA-based name for the paint at their stores.
Old 04-10-2011, 04:54 PM   #17
Trailer: 1971 Amerigo
I was just at Lowes - where they've started asking for your phone number with every transaction - and saw this Rustoleum cabinet - countertop refinish system.
Not sure about it's viability on fiberglass but the countertop samples looked pretty good for a paint on system
Rust-Oleum's Cabinet and Countertop Transformations™ - A Revolutionary Kitchen Transformation System
Peter_Crowl is offline   Reply With Quote
Old 04-10-2011, 05:06 PM   #18
Vickie B.'s Avatar
Nebraska
Donna, I was just being silly about my embarrassing pipe fiasco! I appreciate your finding that lead for me!
Peter, they tried to show me that, too! Maybe I should go back and look at it!
Old 04-10-2011, 05:21 PM   #19
It looked good - but then the displays always look good. When I try to do Faux Finishes or things like that I usually end up looking like a deranged 4 year old covered in paint.
Old 04-10-2011, 06:13 PM   #20
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by Vickie B. View Post
Francesca,
Thanks for all the info. So if I use that primer, what kind of paint would you suggest over it. I want something shiny like the fiberglass.
Thanks!
Vickie,
The beauty of these primers is that you can topcoat them with almost ANY paint except those with solvents that may lift the primer. When properly applied, they strongly adhere to the project surface, and provide a base coat that will hold your paint like glue. My paint preference is acrylic latex (easy to work with), and any paint store can mix you the color you want in your choice of gloss.
I actually found out about this one by asking at True Value if there was any paint that could be used on laminated cupboards in one of our rentals. They introduced me to this primer, and the repainted cupboards have stood up through several sets of tenants.
As I recall, I spent more on the primer than the paint, but since the success of a paint project is critically dependent on surface preparation, it was money well spent. Do also keep in mind that most paints need at least a week of cure time before they achieve maximum strength, and your repainted surfaces will wear very well. Unless you're painting tire treads...see below. Friction will overcome!
I only wish somebody had clued me in to the whole primer-for-plastic thing before I spent big bucks on "special plastic paint" for this locally famous "Turn The Pink Barbie Jeep Into A Green Ranger Jeep" project.
Good Luck!
Francesca
Old 04-10-2011, 06:49 PM   #21
Vickie B.'s Avatar
Nebraska
Thanks Francesca! You are a wealth of info!!!!!
Being a lover and collector of Barbies, it's almost "unthinkable" painting a pink jeep---EXCEPT--that turned out great and how cute are those little travelers?!?!?!? Love it!!!
Talk about repurposing!
Old 04-10-2011, 07:33 PM   #22
Chris McVeigh's Avatar
Trailer: 1978 Trillium 4500
Nova Scotia
Melamine paint that I am used to is a urathane reinforced enamel oil paint that has a low sheen finish - less than semigloss maybe even a little less than eggshell
Ben Moore makes it as well as Glidden etc
It does lay down smooth with an even finish and resists scuffs - smells strong too. For an oil based paint it is pretty flexable.
There are some acrylic versions out now but I've not used them and most likely the products that people are commenting on are the oil based ones
By the way suppliers are in the process of phasing out most residential oil based paint so that may be a reason why it may be he harder to find.
Chris McVeigh is offline   Reply With Quote
Old 04-10-2011, 07:38 PM   #23
Vickie B.'s Avatar
Nebraska
Yikes! Lots to think about!
Old 04-10-2011, 07:53 PM   #24
Smile
The decision to repaint was not made lightly, and was undertaken with the full approval of the original owner, pictured above in her fashionable Jammies-With-Fur-And-Too-Much-Hat-For-The-Picture ensemble.
We made sure to keep a reminder of the Jeep's provenance. If you look closely you'll see that the shifter (the source of all power) is preserved in the original purple. Also, the steering wheel center sports a fine picture of Barbie Herself in Full Ranger Gear.
Wouldn't do to let the boy forget where the Jeep came from!
Francesca
Old 04-10-2011, 07:59 PM   #25
Vickie B.'s Avatar
Nebraska
Truth be known, Barbie secretly confided in me that she is sick to death of everything PINK---pink cars, bar-b-qs, campers, swimming pools, furniture!
I've tried to give her a break!
Old 04-10-2011, 08:09 PM   #26
Ah, but the pink will out...
The boy swears that the mysterious pink smear on the Jeep's hood is the result of his unfortunate encounter with the swingset.
I'm not so sure...
Francesca
Old 04-10-2011, 08:29 PM   #27
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
Vickie,
My recommendation would be to find the paint you want to use and use the primer that the manufacturer recommends. Alot of paints work as a system and you can have compatibility problems by not using primers and paints made to work together. A place like Benj. Moore will be able to advise you on a system that will do what you want it to do with the skill set and tools you have available to you.
Reid Larsen is offline   Reply With Quote
Old 04-10-2011, 08:37 PM   #28
Vickie B.'s Avatar
Nebraska
Good point, Reid. Especially going to a real paint store where they know their stuff instead of Walmart or Lowes!
paint
What should I buy? gianine c Care and Feeding of Molded Fiberglass Trailers 9 11-05-2010 03:19 PM
Has any one used Melamine Paint? Gene B Problem Solving | Owners Helping Owners 3 06-13-2009 10:48 PM
if you were gonna buy a new tow veichle, what would you buy? Robin G General Chat 43 01-21-2009 07:04 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
Need help what to buy General Chat 0 12-31-1969 07:00 PM
