where to hang a towel in a 13'? - Page 2 - Fiberglass RV
Old 08-12-2014, 01:14 PM   #15
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hi Wallo,
I ran over to family dollar today. I got a tension shower rod pole and a tension cafe rod. Space was 46.5 inches.
I bought both because I wondered if the shower tension rod might hold up towel weight a little better (wet towels)?
Let me know whatcha think friend. The one I had in the basement was too small.
Wendy
Old 08-12-2014, 01:55 PM   #16
Wallo's Avatar
Utah
Wendy, the tension rod I use is a small diameter curtain rod, I give it alot of tension and it holds wet towels well. I use the microfiber bath towel which is lighter than a normal bath towel.
Alice
Wallo is offline   Reply With Quote
Old 08-12-2014, 02:30 PM   #17
honda03842's Avatar
Name: Norm and Ginny
The Gilda solution is the one we use when it's not too pleasant outside, it works well.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-12-2014, 02:48 PM   #18
I have used a long curtain tension rod between my cabinets over the table/bed. The trim molding on the cabinets keep the rod from slipping down.
Frank
Frank F
frankcfx is offline   Reply With Quote
Old 08-12-2014, 03:09 PM   #19
Trailer: 77 Scamp 13
Originally Posted by Wallo View Post
.... I also use very short ones inside the cupboards to keep contents in if the door pops open while traveling.
Those short rods can also be used to hold things back in a fridge. Keeps everything snug so it can't bounce around too.
Old 08-12-2014, 04:17 PM   #20
Joy A's Avatar
If you have the rear overhead cabinet you could do a permanent solution as I did.
I cut two 1 inch dowels to size to fit on both sides of the trailer. I painted them white and ran screws from the inside of the cabinets into the dowels.
I mounted them far enough from the windows in case I ever need hanging clothes, the hanger/clothes won't hit the window. This also allowed for me to add little shelves behind the rods. I use the streetside for kitchen towels and the curbside for bath towels.
Here's a couple of pictures.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 08-12-2014, 04:57 PM   #21
CampyTime's Avatar
What a creative idea, Joy! I have the 2 side cabs in my scamper though. Would have preferred the long overhead, but "you gets what you gets" when you buy someone else's ideas in a used trailer. No complaints though!
How to hang curtains Somey Modifications, Alterations and Updates 5 04-02-2011 01:08 PM
New towel rails won't kink or bend if you bump into them. peterh Modifications, Alterations and Updates 1 04-21-2008 06:53 AM
Towel rack Per Walthinsen Modifications, Alterations and Updates 6 03-24-2007 11:10 AM
new tires, rv place did not hang spare tire potteralice Problem Solving | Owners Helping Owners 13 11-27-2006 09:29 AM
Hang 16 lbs on a skinny inner wall? S Sato Problem Solving | Owners Helping Owners 19 11-30-2005 02:18 AM
