Where to run the 7-pin wires? - Page 2 - Fiberglass RV
Old 11-23-2015, 04:11 PM   #21
Originally Posted by Lora View Post
Thank you for that excellent suggestion, RogerDat. It took me a couple of times of reading to get the picture, but I finally did! Very clever.
Bob in Mb, I will be putting in a converter. And, I will use it for the internal lighting. I can't imagine that there is any point at which the 7-pin is tied into this system, except maybe the 12V charging wire? I'd have to take another look at my notes which are currently at home. Please, correct me if I am wrong.
Yes, your charging wire from the 7 pin will have to go to the battery/converter as well as a bonding wire from the TV's ground in that bundle to your ground buss/battery (-) side. As mentioned, bad grounds are the things that generate problems. ALSO: Use quality crimp-on terminals and splices for you wiring and get a pressure crimper (not the pliers kind) for crimping. Cheapo wire terminals are well know for becoming loose terminals, sometimes within weeks of installation.
And wire nuts and Scotch-Locs, fergetit.....
Old 11-23-2015, 04:46 PM   #22
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
You have not mentioned whether you will have a battery in the camper.
We do not have a battery in the camper we use the vehicle battery if we need to use 12V and have a small solar charger if we kill the battery or are staying for a while. We have LED lights and that is all the power we use if at a non-electrical site , so power consumption is very limited.
In any case all your interior wiring will begin at the converter.
Your tail lights , turn signals , running lights , brake lights , and brake controler will run directly from the source.
As mentioned before white is ground and black is hot on interior wiring.
Turn signal etc. color code will vary depending on manufacturer but white should be always ground.
Do not use 12V for your fridge when camping , only when travelling , it is a battery killer.
You converter should have simple instructions that are easy to follow.
Bob in Mb is offline   Reply With Quote
Volvo European 7-pin to US 7-pin EllPea in CA Towing, Hitching, Axles and Running Gear 51 09-18-2015 05:05 AM
Lighting wires and sink pump wires in Burro Kemoldenhauer Problem Solving | Owners Helping Owners 3 08-14-2013 10:06 AM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
Electrical Dilemma (Crossing fingers and not wires!) Legacy Posts Problem Solving | Owners Helping Owners 13 06-06-2003 09:03 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
