Old 01-07-2012, 09:04 PM   #1
Saskatchewan
Why is silicone bad?
I have read that silicone is bad. Is death for your camper. Is the worst thing ever used. I would like to know why? How do you get rid of it? What do you use instead? I hope none of you are rolling your eyes at such a newbie, I truly don't know what I am doing!
Farren and Heather is offline   Reply With Quote
Old 01-07-2012, 09:18 PM   #2
Trailer: Fiber Stream
Wink Links to some required reading. There will be a test after.
Butyl Tape, Silicone and sealing
Help with silicone removal
Why not Silicone?
Alternatives to silicone
Removing silicone!
Old 01-07-2012, 10:46 PM   #3
Trailer: not yet
WOW! This is just one reason why I love this forum, great practical information. I have had trouble using silicone around the house and always thought it was me.
LeonardS is offline   Reply With Quote
Old 01-08-2012, 05:03 AM   #4
Trailer: 2007 Eggcamper
I wish I had seen this before putting in my 2 Fantastic-Fans.
Art
PS I followed the instructions that came with the fans.
artspe is offline   Reply With Quote
Old 01-11-2012, 04:27 PM   #5
Name: Dave and Shelly
Trailer: 2001 Spirit Deluxe Casita "New Name: Eggspensive"
Iowa
I don't even have a camper yet and i found this extremely helpful! DH is all over things with the silicone. Good to know before i find an issue. Thanks everyone. This site rocks!
sfoss is offline   Reply With Quote
Old 01-11-2012, 06:05 PM   #6
IMHO Silicone is a temporary fix that can be permanent problem (to remove it!). Any window, vent or other opening on a molded fiberglass trailer will eventually develop leaks. Your choices are to install the item(s) properly using quality product, knowing that "someday" you'll be removing it for a reseal. I'd rather use something that lasts years and is easy to remove.. like butyl.
But, since it's your trailer and not mine, you are welcome to use whatever you want.... just stay away from mine!
Double Yolk
1988 16' Scamp Deluxe
Old 01-11-2012, 08:37 PM   #7
Trailer: Trillium 1300 Nor'Easter Egg '06 Ranger Supercab 3.0L auto
Newfoundland
Send a message via Skype™ to Richard Hayes
Thumbs up
Silicone has a couple of bad characteristics that can cause problems. The first is that it tends to cure to a rubbery consistency but has poor adhesive properties - as the sealed area is flexed, this lets the rubbery bead of caulking 'break loose' from the surface or surfaces, meaning that the seal is no longer watertight. You can imagine the flexing that a trailer does as it is being towed...
I have removed a lot of silicone caulking that sailors have used on their boats that has subsequently leaked - and caused major damage to the boat - as a general rule, the bead of cured silicone peels right off, right easy, because there is water lodged behind it.
I've also sweat blood removing 40 year old butyl tape when reseating deck gear on sailboats. This gear is subject to enormous strains and constant movement, and is generally constantly wet, but the tape is usually as good as the day it was installed.
The second problem is the residue that silicone leaves behind - it's kinda super-slick, you can't see or feel it, but unless you get it all off, which is a hellishly difficult thing to do and involves chemicals which can eat your liver for lunch, nothing else will ever stick to the surfaces it has touched. Most marine stores, if not RV places, carry rolls of butyl tape in varying thicknesses and widths - it is, IMHO, the only caulking material to use in any situation where flexing can occur and you need a dependable waterproof seal.
Richard Hayes is offline   Reply With Quote
Old 01-15-2012, 10:03 PM   #8
Trailer: 16 foot Scamp
One of the refernced links mentions using innertube as gasket material. A far better material is rubber pond liner. It is uniform in thickness, similar consistency to innertube, and the best attribute is that it is UV resistant. I use it for all sorts of things.
DavidSo is offline   Reply With Quote
Old 01-16-2012, 11:02 AM   #9
Trailer: 2009 17 ft Eggcamper / 2011 Toyota Tundra
Years ago, when we had a sailboat, I was told that silicone makes a good gasket material, but a terrible caulk. Any thoughts on it as a gasket material?
Old 01-16-2012, 12:51 PM   #10
bomni's Avatar
Name: Matt and Lindsey
Trailer: 1972 Boler 1300
It's funny, last night while I was spending literally hours, unsuccessfully, trying to remove what felt like an entire giant tube of silicone from the bottom of my Boler cabinets, I was thinking about starting a thread called....'why I hate silicone'....silicone is the bain of my time spent doing our restoration. I am a female who try's not to swear, but.....
bomni is online now   Reply With Quote
Old 01-16-2012, 03:54 PM   #11
P. Raz's Avatar
Vermont
go ahead and swear, we understand. Raz
P. Raz is offline   Reply With Quote
butyl tape, leaks, silicone
Why not Silicone? melissab Problem Solving -- Owners Helping Owners 17 09-19-2010 10:57 AM
Removing silicone! Crystal, Huscroft Care and Feeding of Molded Fiberglass Trailers 30 07-28-2009 10:38 AM
Silicone VS Vulkem VS ?? Kevin Problem Solving -- Owners Helping Owners 9 01-01-2008 07:04 AM
Help with silicone removal John Perry Care and Feeding of Molded Fiberglass Trailers 30 10-06-2006 09:25 AM
Use that WD-40 or Silicone Spray Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-26-2002 03:38 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
