Window film removal - Fiberglass RV
Old 06-08-2015, 03:29 PM   #1
Trailer: Escape 5.0 TA
Window film removal
I have a fiberglass camper on which the previous owner installed a window film on all the windows to reduce solar gain. I want to remove the film. Has anyone out there found a successful way to remove window film?
starbrightsteve is offline   Reply With Quote
Old 06-08-2015, 05:09 PM   #2
Have you tried to peal it off?
Old 06-08-2015, 05:10 PM   #3
theresa p's Avatar
New Brunswick
Steve----we've both applied and removed it on other vehicles. It is applied using water in a spray bottle...and to remove it, we simply did the same...only we used warm water. if you can get a corner to lift a bit, tease and spray until the whole piece lifts off. Hope you have as good luck with it as we did.
Old 06-08-2015, 05:12 PM   #4
Look on Youtube
Old 06-10-2015, 06:52 AM   #5
Thanks!
Thanks for the u tube tip.
Steve
Attaching Window Film on Door Glass barryra Modifications, Alterations and Updates 6 07-27-2013 02:03 PM
Fluid Film 15% Discount Dextersp1 Care and Feeding of Molded Fiberglass Trailers 5 01-20-2013 06:39 AM
removeable window film (for privacy) jrbowers07 Modifications, Alterations and Updates 5 10-12-2012 02:26 PM
U-Haul CT Stalker Film Matt in SV Modifications, Alterations and Updates 9 08-25-2011 01:02 PM
Privacy Film Alternative/Privacy Screens Bill&Ann Modifications, Alterations and Updates 1 05-29-2009 10:04 PM
