window problems - Fiberglass RV
Old 04-03-2016, 10:03 AM   #1
Name: BRIAN AND TERI
Trailer: BOLER
window problems
I am having some window problems on my 1973 Boler.
The rear right window crank doesn't do anything anymore.
Is there something to adjust, or replace?
The other problem that just happened is the roller in the door window seems to be missing and it can't close tightly.
Where can you get parts, and how can you fix that?
Thanks from Kelowna, B.C. Canada
BRIAN AND TERI is offline   Reply With Quote
Old 04-03-2016, 11:03 AM   #2
IllAnnoy
The window handle is usually attached to a splined shaft held in place with a screw in the center. It could be as simple as tightening that screw.
If not, remove the handle and see if the splines are worn. If there is wear, you could place a small piece of aluminum foil over the splines then replace the handle.
If the shaft turns freely with the handle removed without moving the glass then further work will be required and maybe parts.
Old 04-03-2016, 12:36 PM   #3
vintage trailer supply has several different window operators available. That's the little gear box the crank handle attaches to. I've found a couple different ones at my local hardware store.
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Scamp Window Problems Parker Buckley Problem Solving | Owners Helping Owners 5 01-26-2008 11:29 AM
Problems with latch on Casita exit window Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 11-27-2002 11:29 AM
