Window Seals and Leaks - Fiberglass RV
Old 05-08-2016, 12:53 PM   #1
Trailer: U Haul CT 13 - 1984
Ohio
Smile Window Seals and Leaks
Hello,
I am new to this blog and only signing in to give my information. I have a U Haul CT 13, 1984. I started with the side windows. I replaced everything and even some of the glass that had been replaced with plexiglass. I then pulled the back window and have it ready to go back in. Today, I pulled the door window because someone had put it in backwards. I was hesitant to post because all of my labor wasn't paying off. My windows leaked horribly. Today I found that you have to cut a hole in the flocked channel at the same spot as the drain hole. Once I did this, I did a test in the sink and no water came through to the other side. I will keep everyone posted as I proceed now that I am sure I figured out the problem. I will shortly post all companies, product numbers, and photos.
Darla
Coleslaw is offline   Reply With Quote
Old 05-10-2016, 08:49 AM   #2
Trailer: 1979 Bigfoot 17'
Saskatchewan
Please do post pics when you are finished!
Livia is offline   Reply With Quote
Old 05-14-2016, 10:29 AM   #3
pjanits's Avatar
Trailer: 17 ft 1986 Burro
My 86 Burro 17 window leak
I had a window leak in the rear window or years, intermittent. Drove me nuts. Pulled the window several times and found nothing.
The leak alternated from the left side to the right side or didn't leak at all.
One day I was inside during a pretty hard rain and noticed the center slide window track filling with water and overflowing into the inside track which then overflowed unto the back wall getting the bed wet. That was the leak!!!! The center track has no way to exit the water! I used a dremel tool with a metal cutting bit and cut drain slots on the center track right by the normal rain slots. Been good for over a year now.
leaks
Trillium Belly Band and Window Seals garry g Modifications, Alterations and Updates 4 01-25-2016 09:24 AM
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
boler Side window - Restoring (need List of Seals and where to order) idiotsniff Modifications, Alterations and Updates 20 01-14-2012 08:43 PM
The Window to my Burro leaks Casey G Problem Solving | Owners Helping Owners 9 04-22-2011 07:07 PM
Replacement window seals and gaskets Mila Care and Feeding of Molded Fiberglass Trailers 1 05-05-2008 09:56 AM
