Window Stone Guard - Fiberglass RV
Old 12-18-2006, 08:47 PM   #1
james kent's Avatar
Trailer: Boler 1984
Has eneyone used an existing stoneguard as a mold to make a second one? If you have, what difficulties did you have, if any? I've been thinking that it would be nice to have one at the rear as well as at the front. Both to protect the trailer when closed and to act as an awning when open. Sure would help keep the place cool when the sun shines.
Old 12-19-2006, 06:29 AM   #2
James I've seen pictures of folks that have done this. On a Scamp, the back window is a different size than the front..otherwise a Scamp owner (I realize you have a Boler) could order the gravel shield and install. Also the back glass is flat, where the front fiberglass is curved. Have you considered getting a flat piece of fiberglass (used in shower stalls?), cutting it to fit and installing that? You could also buy the black (or other color) trim that has the metal core and rivet that around the outside to finish off the fiberglass rough edges. Just a thought.
Old 12-19-2006, 07:26 AM   #3
Trailer: Scamp 13 ft
Hi,
I have an '83 Scamp 13' and have had a "gravel gaurd" on the rear window for the past 13 years. It actually came from the factory with the hardware mounted over and under the window, but no gaurd, so I purchased one from them. I too use it more to keep the sun out of the camper, and yet, it does work well as an awning while camping. So, if you have an older Boler, the front and back windows (if non-opening) are the same curve and the same size. Hope this helps.
Chris L. is offline   Reply With Quote
Old 12-19-2006, 08:44 AM   #4
james kent's Avatar
Trailer: Boler 1984
My front guard is moulded and has a raised centre. I'm wondering about the difficulties of making one the same. Now while we'resanding and refinishing the outside I have the guard off and this would be a good time. If i cover it with plasticto act as a release will the glass and renin conform to the shape or leave a gap around the raised edge?
Old 12-19-2006, 08:47 AM   #5
james kent's Avatar
Trailer: Boler 1984
Wow!
Excuse the bad spelling. Put it down to doing the two finger dance on the keboard.
how do i open front window stone guard on 73 trillium ? Garry Vanderzwet Problem Solving | Owners Helping Owners 6 05-20-2009 02:38 PM
FOUND - Trillium Window Stone Guard Wanted michael 01 Classified Archives 10 05-10-2009 03:08 PM
Wanted: Fiberglass front window stone guard Craig B. Classified Archives 0 03-22-2009 08:58 PM
wanted stone guard for window Erik J Classified Archives 12 02-24-2006 10:09 AM
Front Window Stone Guard Legacy Posts Problem Solving | Owners Helping Owners 16 05-11-2003 10:54 PM
