windows leak weatherstripping source? - Fiberglass RV
Old 11-25-2016, 06:12 PM   #1
Trailer: U Haul
I have a 1985 U Haul trailer. The windows leak. The fuzzy weather stripping around these windows has rotted out. It is "u-shaped" in profile. I cannot seem to find replacement material. Ideas? I would consider "work around" alternatives.
AnneWhitfield is offline   Reply With Quote
Old 11-25-2016, 09:13 PM   #2
Lots of info and parts sources on the Uhaul Facebook group. Look in the "files" section there. Uhaul windows are typical leakers but they can be rebuilt.
Old 11-26-2016, 07:28 AM   #3
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Parts info is in the files section here but is 1 update older
mmeyer is offline   Reply With Quote
Old 11-26-2016, 11:51 PM   #4
Trailer: Trails West
Not sure exactly which felt seal the Uhaul used. However if you don't get a link then you need the following information to find a replacement.
Width and depth of the track it fits into
thickness of the window glass
of course you need to know how many feet of it you need
and you need the right keywords....
"glass run channel" You can add the word "felted" to that keyword search but nowadays there are also all silicone versions of that seal which I suspect is the better way to go versus the older felted styles that let water into the channel since they don't seal as tightly against the glass due to their fuzzy nature.
Old 11-27-2016, 07:53 AM   #5
Uhaul side windows, and the door window, are mounted in a rubber weatherstrip that has a lock strip to tighten it against the shell and window frame. A couple years ago some New old stock (NOS) Uhaul windows were available. Which weatherstrip to use is a debatable topic. Some people had leaks after installing the new windows with new weatherstrip. Leaking side windows was a problem way back when these trailers were in Uhaul's rental fleet, and their solution, which you can find in the repair manual, was to use some caulk under the rubber weatherstrip. I installed one of those NOS windows and it does not leak. Installed two for another Uhaul owner and was told they do not leak. Best solution though is to find a clamp ring type window that can be made to fit. I made modifications on our Uhaul to use a Scamp side jalousie window and a rear window.
Old 11-27-2016, 08:12 AM   #6
Trailer: U Haul
Smile window leaks
Thank you so much, K. Corbin and Mary and Bob! I plan to work on the trailer tomorrow. This gives me direction and good advice!
Old 11-27-2016, 06:11 PM   #7
Anne, did you see the reply on the Uhaul parts exchange Facebook page?
windows
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Leak source: tiny holes in roof.... artrageous Problem Solving | Owners Helping Owners 16 05-19-2015 03:00 PM
Source for stove and windows and such? Vic&Kathy Modifications, Alterations and Updates 6 03-21-2015 10:16 AM
Source for small double glazed windows ? Westcliffe01 Care and Feeding of Molded Fiberglass Trailers 18 10-03-2013 06:52 PM
Weatherstripping help needed Robin H Problem Solving | Owners Helping Owners 7 07-16-2007 07:52 PM
» Trailer Showcase
pullet
bobgin12
UHaul
Calud13
