Windows leaking? - Fiberglass RV
Old 07-17-2013, 01:05 PM   #1
willisworms's Avatar
Trailer: Beachcomber B15
Kelowna, B.C. Canada
Windows leaking?
So I was working in my trailer as it was raining out. My windows have been completely rebuilt, with all new felt sliders. The rain was coming down pretty good outside, and I noticed a trail of water running down the inner wall. No way! I thought, fresh butyl, then a bead of sealant around the whole thing, a leak should be impossible. So I went outside to inspect. All sealing points were fine, but the felt slider was full of water. Now I notice that the sliding half of the window is sitting in the felt. The water that hits this half of the window, runs down the glass, and into the felt slider. The felt then fills up, the drain holes at the bottom of the windows are clear, and I would assume, should drain out said water. In this case the rain was filling the felt slider faster than it could drain, and the excess water was coming inside. Is this a normal issue? This seems unacceptable to me. The trailer is jacked up as I was doing wheel bearings, it is by no means level, and it's the high side windows that are leaking. Will this not happen when level?
Just working in the shop
willisworms is offline   Reply With Quote
Old 07-17-2013, 01:17 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
The felt slider needs to have holes cut into it that match with the drain holes in the aluminum track. It is possible to have problems when not level, but be are OK when level. I drilled some additional drain holes in the corners of my UHaul to address this possibility
Old 07-17-2013, 01:29 PM   #3
That makes complete Sense! Thanks! I did not cut out the felt. One more thing on my list!
Old 07-17-2013, 02:25 PM   #4
Thomas G.'s Avatar
Don't feel bad- it is a common mistake. I marked the felt by reaching through the drain hole, then pulled up the felt so I could access it fully. Then I cut holes with an Exacto knife.
Old 07-17-2013, 02:57 PM   #5
Thanks again for the heads up, slots are now cut in the felt.
Old 07-17-2013, 06:58 PM   #6
papa-t's Avatar
Glade Valley, North Carolina
Anyone ever add new drain holes to the bottom of the windows? My Scamp of course has one on each end of the bottom track. Looks like on the larger windows like the rear one it would have more that just two; just for heavy rain safety. IMO
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
windows
Help! My Windows Are Leaking! lauramoncur Problem Solving | Owners Helping Owners 17 05-06-2012 06:25 PM
Leaking windows Hélène L Problem Solving | Owners Helping Owners 4 02-17-2009 06:51 PM
Leaking windows? Lenna F Problem Solving | Owners Helping Owners 3 09-20-2007 02:36 PM
Leaking windows Stephen Brown Problem Solving | Owners Helping Owners 29 08-04-2007 02:31 PM
Leaking windows GrahamD Problem Solving | Owners Helping Owners 1 07-15-2006 05:39 PM
