Windows need serious cleaning help - Fiberglass RV
Old 09-04-2017, 09:26 PM   #1
Snoopwagon's Avatar
Im wondering if anyone else has had this going on! My windows on my rv have what I originally thought was left over adhesive from old window tint! I now know it is not and keep in mind its a fiberglass trailer weather it matters or not relating to this issue remains to be seen it almost looks like water spots however after taking a muratic acid solution on a sponge carefully on glass only followed by soapy water to neutralize did not even phase it What the heck help glass expert I know your out there what are these white spots on my windows?
Snoopwagon is offline   Reply With Quote
Old 09-04-2017, 10:01 PM   #2
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
Is it oxidized fiberglass gelcoat or paint overspray? Not familiar with muriatic acid spot removal, but vinegar is a common hardness remover. If that doesn't work, and your windows are glass, how about some non-scratching cleanser powder and water with a non scratching scrubbing pad.
Old 09-04-2017, 10:31 PM   #3
Snoopwagon's Avatar
I will try vinegar For sure, pretty sure your right on the oxidation I think the roof has been a little forgotten alittle by previous owners I get it not everyone has scaffolding it makes it easier to maintain the roof/ time to get it any suggestions on a remover compound?
Old 09-04-2017, 10:32 PM   #4
Snoopwagon's Avatar
Big help Raspy 👍
Old 09-04-2017, 10:42 PM   #5
Raspy's Avatar
I suggest Comet Cleanser, or equivalent. It is an old school powdered cleanser available in supermarkets and big box stores. It is advertised as "non-scratching". Then those kitchen scrubby pad/sponges that also say "non-scratching".
Good luck.
Old 09-05-2017, 01:29 PM   #6
Trailer: Sprinter 'til I buy
Denver, CO
Comet contains a mild abrasive, so keep that in mind.
Another substance good on glass is ammonia, Many glass cleaners contain it. More used to. Do not use ammonia around bleach, as they are toxic. Comet or similar scouring powders could contain bleach, so rinse them off first. The fumes from ammonia should be well ventilated.
An old favorite to clean glass is wadded up newspapers with ammonia.
Tom 72 is offline   Reply With Quote
Old 09-05-2017, 02:10 PM   #7
IllAnnoy
how about a single edge razor blade?
Old 09-05-2017, 03:24 PM   #8
Trailer: Escape 5.0 TA
W. Mass
I had what sounds like the same spotting all over my windows, thought it might be from cleaning a lot of stains the trailer got on it with Simple Green. A few weeks back I took a paste of Comet to the windows, rubbed in good and rinsed off well. Then used RainX, also rubbed in good, came out pretty darn good, removed something like 90% of the spotting.
Time will tell how long it lasts.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 09-05-2017, 04:52 PM   #9
Trailer: Trillium 4500 & Boler 1700
Comet is great but abrasive. I would try gentle cleaners first, especially ones listed for glass. It's a crap shoot when you don't know what you are trying to remove from the surface. My favorites are gel gloss, Krud kutter, Goof Off Pro Strength (Quite nasty but listed for fiberglass and glass) , maybe magic eraster, maybe bar keepers friend ( becareful with that one and read directions, may etch but listed for fiberglass and anodized aluminum if used carefully). Maybe some of the cleaners for glass cook tops.
Also some of the scrubbing bubbles for either bathroom or kitchen might work.
Good Luck!
Lisa in Michigan is online now   Reply With Quote
Old 09-05-2017, 04:56 PM   #10
Test everything inconscipious sport first.
Old 09-05-2017, 05:15 PM   #11
IF the windows are etched, nothing is going to remove the spots, except an expert glazier that can polish glass, it wouldn't be cheap. You might TRY the liquid/paste used to clean glass-top stoves.
Old 09-05-2017, 05:33 PM   #12
Bernese Bunch's Avatar
Trailer: 2015 Lil Snoozy
Delaware
The guys who clean my windows in my home use liquid dish detergent and a very fine steel wool. They tell me glass is actually porous and dirt adheres to the surface grooves. That's the reason why you can get a haze using plain window sprays. The dirt just gets smeared around on the glass. I've used this method on my cars windshield and it's a miracle! Thank goodness for those pros! Good luck
Bernese Bunch is offline   Reply With Quote
Old 09-05-2017, 08:34 PM   #13
Fine steel wool is indeed the correct thing to do. Just adding the additional information that the place to find the superfine steel wool it is in the paint department section of your local hardware store.
Old 09-06-2017, 08:02 AM   #14
rbryan's Avatar
Arkansas
Yep. Sold where they sell sandpaper usually. Get the 0000 (we call it "4 aught").
By the way, it does a great job on wood. I lacquered some cabinetry and doors awhile back that turned out to be a bit too shiny for my liking. Gave them the once over with 0000 steel wool and now the finish is an even satin. On a harder surface like glass, the effect is only to clean.
Old 09-06-2017, 12:33 PM   #15
I have had good success using the clay bar used in a clay polishing kit used to polish cars. Only on glass not plastic windows.
MothersĀ® California GoldĀ® Clay Bar Kit
Old 09-10-2017, 11:39 AM   #16
Trailer: Trail Cruiser
The best way to remove the debris will depend on what it actually is.
Muriatic acid is a solution of hydrochloric and water It is stronger than vinegar, which is a weak solution of acetic acid and water. Both will work for removing metallic salts which are often calcium based and found in "hard water". These metallic salts usually have a rough surface will will trap other debris as well, adding to the stain.
Paint overspray, waxes and road debris often contains hydrocarbons which will require a solvent for removal. Acetone may help. Most automotive vehicle waxes will contain hydrocarbon solvents which will penetrate this debris and trap it in the haze which you will wipe off.
Many abrasive scouring powders contain a fine silica sand. Glass is made from melted silica so these abrasives can scratch the glass.
A scotch pad is made from a plastic polymer. It can physically scrape the debris from glass but isn't hard enough to scratch the surface of the glass.
A single sided razor blade also isn't hard enough to scratch the glass but can be used to scrape debris from its surface.
Old 09-16-2017, 11:46 AM   #17
Snoopwagon's Avatar
Thank you for your window tips very helpful!
Old 09-16-2017, 12:06 PM   #18
Delaware
So, Snoopwagon....did you get the crud off? Which method worked?
Old 02-17-2018, 08:40 AM   #19
today a new thing
well today I learned how to clean windows! Something new everyday on the fiberglass Rv!!
bob
Old 02-17-2018, 04:34 PM   #20
Originally Posted by Snoopwagon View Post
...My windows on my rv have what I originally thought was left over adhesive from old window tint! I now know it is not a...it almost looks like water spots ...
Pitting from acid rain perhaps? That can't be cleaned away!
Yes.. you must know if the window is in fact glass. Not everyone knows that the front window is plastic, and I think some have damaged it by cleaning it as if it was glass. My understanding is that ammonia based window cleaners are bad for the Plexiglas.
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Uhaul Owner - Serious Question Mike H. General Chat 2 04-10-2006 07:28 AM
Serious Snowblower Pete Dumbleton General Chat 5 01-01-2006 10:37 PM
This is serious! Legacy Posts Jokes, Stories & Tall Tales 21 05-02-2003 07:35 AM
A serious question General Chat 0 01-01-1970 12:00 AM
