Windows not sealing - Fiberglass RV
Old 08-20-2008, 05:22 PM   #1
Trailer: 1977 Scamp
Hi all. I'm looking at purchasing a 1977 Boler - everything looks great with it, except the windows don't close all the way when they are cranked down. So here's my dumb question: Will it just need some crank parts replaced and are they readily available? or do the entire windows need to be replaced? and how readily available are replacement windows? Everything else with the windows are fine, they just do not seal completely tight when they are cranked closed. Thanks for any help.
Doug C2 is offline   Reply With Quote
Old 08-20-2008, 06:29 PM   #2
Hi Doug, I'm sure someone will answer up shortly. In the meantime, here's a link to a number of Window and Window Parts from our Helpful-Links pages. As you can tell, there's a number of resources for the jalousie windows.
Old 08-20-2008, 07:07 PM   #3
Alf S.'s Avatar
Hi: Doug...The bulb seal that goes across the bottom of the window frame where the window glass and frame meets is avail from Vintage Trailer Supply as are the cranks and other window parts for the Jalousie windows. Airstream used these windows and thats why VTS has resurrected some of the seals and gaskets. That's where I got a lot of seals and window parts for our former '77 Boler.
windows
Sealing Bigfoot DwayneR Problem Solving | Owners Helping Owners 3 06-13-2010 08:30 AM
Sealing roof perforations-Bigfoot Tony Nowak Problem Solving | Owners Helping Owners 2 07-15-2009 11:48 PM
Compact II fresh water intake and sealing windows??? Pat Goodwin Problem Solving | Owners Helping Owners 5 01-24-2009 05:48 AM
window sealing Ian Harrad Problem Solving | Owners Helping Owners 2 10-03-2006 06:23 PM
Waterproofing & Sealing the Bottom Lindy Auble Care and Feeding of Molded Fiberglass Trailers 10 05-05-2006 06:53 PM
