Winterizing Scamp 19' - Fiberglass RV
Old 10-20-2013, 11:55 AM   #1
Trailer: Escape Trailers
Massachusetts
If I've drained the freshwater, black-water, and gray-water tanks and blown the water out of the water heater, is it necessary to put antifreeze into the system other than to pour 1/2 gallon or so into the black and gray-water tanks?
Thanks,
David
Stretcher is offline   Reply With Quote
Old 10-20-2013, 11:58 AM   #2
Currently a thread going called Parkliner Winterization which you may want to read - winterizing of all brands of trailers have some very common dynamics.
Old 10-21-2013, 07:34 AM   #3
Steve & Terri's Avatar
Name: Steve & Terri
Trailer: 2004 Scamp 19 ft 5th Wheel
The only other place that might need some antifreeze would be the shower drain to the pipes that pump water to the grey tank.
Steve & Terri is offline   Reply With Quote
Old 10-21-2013, 08:23 AM   #4
When you put the antifreeze into the shower drain dont forget to turn on the shower floor pump for a couple of seconds. Also dump some down the kitchen sink - the P trap may be holding some water. One thing I forget to do is the shower head. Dont know why but even after draining out the whole system sometimes if I take the shower head down low, turn it on and shake it, a bit of water comes out - you may not have that problem using the air blow out system but you never know. If you can use your air gun to blow out the hot water tank after it is drained - due to the design of them they do not drain out totally. Past owner of my trailer had tank damage one winter even though he had drained it. I leave the drain cap off of mine in the winter - as a just in case precaution.
Old 10-22-2013, 04:44 AM   #5
Lyndon Laney's Avatar
Trailer: 1996 19 ft Scamp 19 ft 5th Wheel ('TOGETHERNEST' SLEEPS 8
[QUOTE=Stretcher;426251]If I've drained the freshwater, black-water, and gray-water tanks and blown the water out of the water heater, is it necessary to put antifreeze into the system other than to pour 1/2 gallon or so into the black and gray-water tanks?
Thanks,
In my new 96 Scamp I never used antifreeze the first year and the large diameter screen filter before the pump held some water and froze and broke the filter body is larger than the line and is impossible to drain or blow out and will colect water . the only answer is a smll amount of anti freeze.
Lyndon Laney is offline   Reply With Quote
Winterizing My '84 13' Scamp Lil M. Care and Feeding of Molded Fiberglass Trailers 6 10-08-2012 05:47 PM
Un-winterizing a Scamp Wallo Care and Feeding of Molded Fiberglass Trailers 15 02-13-2011 10:09 PM
Winterizing Scamp in Pacific NW HappyScamper Care and Feeding of Molded Fiberglass Trailers 1 10-22-2010 12:00 PM
13' Scamp / Winterizing Question Sheryl M Care and Feeding of Molded Fiberglass Trailers 4 01-03-2008 08:43 PM
Winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 09-20-2002 09:09 AM
