Winterizing the caravan battery. - Fiberglass RV
Old 10-20-2015, 08:42 AM   #1
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
Near the outdoor storage of my trailer, I can connect to an AC 110V outlet. Is it okay to let it connect all winter on the transformer of the trailer?
Merci,
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 10-20-2015, 09:31 AM   #2
The Minimalist's Avatar
Louisiana
I looked on the Bigfoot site and thought it says your trailer has a 45 amp converter with charger, it doesn't specify the type and whether or not it is a 'smart' charger.
I'd say that, if it is a smart charger and won't boil your battery, you could get away with it. Smart charger or not, it would be wise to check your battery water level once a month or so just to make sure.
A fully charged battery shouldn't freeze, unless it gets down to -92 F in Quebec. At that point you probably won't care. {{8-{D}}}
Clif
Old 10-20-2015, 09:54 AM   #3
If it is the original Converter/charger it pretty much pre-dates smart chargers. Look on the front panel and tell us a make and model.
Old 10-20-2015, 10:54 AM   #4
Gilles's Avatar
Quebec
It's a Allardson, Model D20-BRA-A
with 5 fuses, 20 amps each, only 4 are used.
Merci,
Gilles
Bigfoot 25B21RB.
Old 10-20-2015, 11:04 AM   #5
Gilles's Avatar
Quebec
The battery is sealed can not check the water level.
I do not believe that the temperatures fall below -92°F this year, we are told that temperatures are rising these years,
Gilles
Bigfoot 25B21RB.
Old 10-20-2015, 11:11 AM   #6
That converter apparently does not have a smart charger incorporated and, of the mentions I found on-line, there seem to be a few comments about it over charging. With that information I would not leave it plugged in 24/7, but I would remove the battery from the caravan and keep it in a warm place, ad on a battery tender, if desired.
Old 10-20-2015, 11:14 AM   #7
Gilles's Avatar
Quebec
Thank you Bob, that's what I'll do ...
Gilles
Bigfoot 25B21RB.
Old 10-21-2015, 11:49 AM   #8
Roger C H's Avatar
Smile What I do
I just plug in the trailer for one day once a month.
Of course it doesn't get as cold here...
Roger C H is online now   Reply With Quote
Old 10-21-2015, 12:34 PM   #9
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
If you wish to leave the battery in the trailer, and your charger does not do a proper float charge, you could just monitor it every month or two, and check the voltage. If it is low, just plug it in for a day.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 10-21-2015, 01:29 PM   #10
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Merci,
Just make sure the electrolyte (acid) is covering the plates.
Give it a full charge. (13 + volts), Clean off any dirt on top of battery.
Disconnect the Negative cable, and leave it on the trailer.
Old 10-21-2015, 08:41 PM   #11
Trailer: Still Looking
Alabama
You could plug it into a coffee maker timer and let it run for an hour or so a day. Check the resting voltage and adjust it as needed.
Bullington is offline   Reply With Quote
battery
Mon Dieux, A French Vickers Caravan! Roger H General Chat 17 02-14-2006 04:56 PM
Complete Rig: 2003 16' Scamp Travel Trailer and 2000 Dodge Caravan lhayes Classified Archives 0 02-13-2006 05:17 PM
1959 Westfalia Caravan - eBay guy_cerny Classified Archives 1 02-13-2006 01:32 PM
Washington DC Caravan Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 0 12-01-2002 06:11 AM
