I just finished wireing up most of my converter and everything works. I have the
battery temperarily next to the converter and have not run the long line outside to the front yet, or frame ground the 12v side. So far I have the main 30 amp service line coming in with a ground to trailer frame off of this.
When I asked about grounding on a previous post, it was noted that I should have a ground off the trailer frame on the 120v side and the 12v side of my power center. I just read the instructions on installing a 25 amp digital
solar regulator, from Go Power, and it states "Do not connect the negative
solar array or negative
battery regulator wiring to the chassis of the vehicle." I'm assuming the vehicle is the trailer. So does it sound OK to ground the
battery to the trailer frame, but run a full wire line straight to the battery without a frame ground in between. The battery would still be ground, but there would be a dirrect connection between the
solar regulator and battery.
Thanks for any help.
