UPDATE - We were able to use the Peak PKCORB with our Scamp 5er with only some occasional interference. So it was good enough to keep using, which we did.
However, we recently
sold our Scamp and purchased a 2008
Escape 5.0. The distance that the camera must transmit the signal is basically the same as it was in the Scamp. We set everything up exactly the same way. And have discovered that the camera works REALLY well with the
Escape. The only difference seems to be that the
Escape is not lined with Reflectix the way Scamps are. Our Escape does not have the extra insulation which would mean there was a layer of Reflectix lining the trailer.
So, if you are using this with a Scamp it just may be the Reflectix which is the culprit. Not sure if removing a small piece at the nose of the trailer where then transmitter sits would fix the interference...
BTW, if we don't have the camera hooked up, we WILL pick up local TV stations on the monitor....
Fran in NM
