Wireless Camera needs a better antenna - Fiberglass RV
Old 09-04-2018, 09:08 AM   #1
Trailer: Escape
The title says it all. I have a TADI brothers wireless camera on my 21' escape. It is mounted on the rear light and I have problems with intermittent reception. I am looking for better antennas for either the transmitter or receiver to improve reception and am wondering if this antenna, https://www.tadibrothers.com/product...xtension-cable , from TADI Brothers might do the trick if I mount it on the roof of my Escape, or if there is a better option.
AndyF is offline   Reply With Quote
Old 09-04-2018, 09:46 AM   #2
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I tried a wireless camera on our Boler 1700. I put the camera inside at the back window and ran the cable to the front of the trailer so I would have a shorter distance between the transmitter and receiver.
There was still too much interference as I run it as a rear view camera. I ended up hard wiring it.
Old 09-04-2018, 10:17 AM   #3
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I had a Tadi Brothers wireless camera on my Escape 17B, and ran a cable from the camera to the front of the trailer, where I placed the transmitter. Never had a drop out problem.
I currently have an Escape 21 with the factory installed Rear View Safety camera, a model that has a built in transmitter in the camera's case. I was skeptical since the distance was much longer than with the previous system, but I've never had the video dropout. At times, the refresh rate seems to slow down, but never enough to be a problem.
If the antenna you referenced will work with your camera, moving it to the front of the trailer should make a good improvement. I've found Tadi Brothers good to work with - if it doesn't do the trick I suspect you would be able to return it.
Old 09-05-2018, 04:23 PM   #4
Check with Tadi Brothers. They are good to work with and can steer you the right way. Your system should not blank out if it is rated for the distance. Maybe it is faulty so check before you buy more items. Mine works great on my motor home. It is rated for 75 ft.
Old 09-05-2018, 10:32 PM   #5
tractors1's Avatar
Trailer: Escape 21 - Felicity
Also moved my TADI transmitter to the front of my 21; brought the wires up behind the padded drivers side bed corner and mounted the transmitter underneath the front shelf in case I ever need to replace it.
No issues in 4 years - about 10 ft to the receiver I taped to the rear window of the truck (VHB tape.)
Charlie Y
Back-Up/Rear View Wireless Camera Reliability CPW Problem Solving | Owners Helping Owners 14 05-06-2017 09:08 AM
VR3 wireless back up camera John Perry General Chat 2 02-11-2017 10:20 PM
Wireless Rear View Camera Victor Benz Towing, Hitching, Axles and Running Gear 21 10-22-2016 08:50 AM
Wireless Backup Camera Interference Problems Fran L Problem Solving | Owners Helping Owners 6 08-22-2013 02:32 PM
