wires from hubs? - Fiberglass RV
Old 08-22-2010, 08:48 PM   #1
Joe Steadman's Avatar
Trailer: Scamp 13 ft
Army Family
wires from hubs?
I have an 85 13 foot Scamp... well, it has a few wires coming from the hubs? I assume they are for brakes but it also is wired with a flat four prong harness... can you run brakes with only four wires?
Joe Steadman is offline   Reply With Quote
Old 08-22-2010, 08:56 PM   #2
Roy in TO's Avatar
It could be for brakes. Do you have hubs or drums? If drums then you need a 7 pin to get the brakes going.
Old 08-22-2010, 09:23 PM   #3
Army Family
I'll have to take a picture... they are pretty big.
Old 08-23-2010, 05:12 AM   #4
Don N's Avatar
Trailer: 1989 Bigfoot 17'
It could be done by leaving the flat four pin for the lights, etc but you will have to mount a brake controller in the tow vehicle and could just run the hot wire from that back to a single connector for the trailer brakes. It is not the normal or best way to do it but would work in a pinch. The other wire from the hubs has to be grounded. The 7 pin is the better way to do it.
Don N is offline   Reply With Quote
Old 08-23-2010, 07:01 AM   #5
to see if they work:
Get a compass and a battery.
Hold the compass close to the hub and have someone connect the wires to a battery. If the magnets in the hub are working, the compass should move.
Old 08-23-2010, 08:55 AM   #6
Trailer: Fiber Stream
Cool You need at least 5 pins if you have electric trailer brakes
Boat trailers have a flat-Five pin connector so that the trailer brakes can be hooked up, in addition to the basic lights. This would be sufficient if you don't want a battery charge line also. For that I'd recommend getting a 7-pin.
Trailer Wiring Diagrams | etrailer.com
Connecting all those wires. CD Smith Problem Solving | Owners Helping Owners 4 09-09-2013 03:27 PM
HELP! Wires ALL over the place!!! J.S.Lahm Electrical | Charging, Systems, Solar and Generators 6 09-11-2012 06:10 AM
What size hubs do I need for a stock axle? Brian Scott Towing, Hitching, Axles and Running Gear 2 06-03-2008 12:35 AM
Oil filled Hubs Legacy Posts Towing, Hitching, Axles and Running Gear 4 10-29-2002 03:31 PM
What size hubs do I need for a stock axle? Brian Scott Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
