wiring - brown green reed white (and black?) - Fiberglass RV
Old 07-08-2011, 12:34 PM   #1
Trailer: Boler 1300, 1972
Went to put a new 4-flat plug on the trailer this morning (the old one took a little water/ice damage last winter) and found a surprise. Well, not really surprised by anything I find hidden within the boler anymore....
anyway, the existing old plug used the brown/green/red/white wires (the white may have been a yellow at one time, kind of faded now if it was, or yellowing with age if it was white)
peeling back the sheathing a bit to get a good clean new connection point I found a black wire clipped and tucked away inside.
any idea what this was once used for? I know of 7 and 6 pin plugs, but never seen a 5 pin.
I am hoping that there is such a thing as a 5 pin, and that the new surprise wire is to wire up for battery charging.
any how, any ideas?
adriemel83 is offline   Reply With Quote
Old 07-08-2011, 12:41 PM   #2
well, found 5-pin plug info. I was just a little impatient I guess...
I'll modify the question a bit then...
info I found on 5-pin plugs state the 5th pin is for hydraulic/electric brakes, could it be used as a 'hot' line for battery charging?
sure hope so cause I will be installing battery system soon!
Old 07-09-2011, 05:07 AM   #3
james kent's Avatar
Trailer: Boler 1984
white....Ground
red.......Left Turn
green...Tail Lights
brown...Right Turn
black....12 V
blue......Electric Brakes
yellow...Auxillary
These are the most common colour usages for a four, five or seven pin connector.
Old 07-09-2011, 05:13 AM   #4
Trailer: 1991 17 ft Horizon
Adam, I see no reason why you can't use it for what ever you want to, since you don't have elec. brakes. Although it would be nice to have a single plug with a heavier wire for charging, just my opinion.
Old 07-09-2011, 02:46 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
any how, any ideas?
Hi, Adam
You might take a look at the Bolerama page on wiring at Wiring
It gives all the "correct" paths for Boler wiring and has the four-pin diagram available for upload...
Hope this helps!
Francesca
Old 07-09-2011, 03:25 PM   #6
Look here....
Yahoo! Image Detail for - http://www.ak2o.org/kshoe/images/trailer_diagram_2.jpg
Old 07-10-2011, 05:15 PM   #7
james kent's Avatar
Trailer: Boler 1984
I recieved emails re the black wire.
The information came from a wiring diagram for a 7 pin harness.
Old 07-10-2011, 10:01 PM   #8
this is what I am hoping will work out. The next project is to install the battery system, along with the necessary connections for coach charging. So many new things to learn with this Boler!
Old 07-10-2011, 10:04 PM   #9
The diagrams are looking good, thanks for the links. This will work well into my rear blinker not working problem as well. Great to kill two birds with one stone
Old 07-13-2011, 05:29 PM   #10
Jack Walter's Avatar
When I rewired my 1978 Boler I found that the original wire colors did not match up with the now standardized trailer wire color codes so be sure to check which color wires actually connect to the fixtures.
Jack Walter is offline   Reply With Quote
Old 07-13-2011, 05:33 PM   #11
I had the same problem , but with a test light you can work around most problems.
From Fuzzy Green to Gleaming White Anne H General Chat 5 04-25-2011 06:46 PM
Big brown Black Bear & Solar Panel Perry J General Chat 3 06-25-2010 05:24 PM
Black or White Tongue Box? Lisa H. Care and Feeding of Molded Fiberglass Trailers 19 06-01-2009 10:34 AM
Brown County Indiana, anyone? Chris Z Rallies, Get-togethers, Molded Meets (Archive) 32 10-17-2007 07:46 PM
» Trailer Showcase
Laika
AnnKola
Bob
Wobble
