wiring harness plug in - Fiberglass RV
Old 12-15-2002, 11:48 AM   #1
Late one afternoon while driving along, I checked the mirror for marker lights on the trailer; seeing none, we pulled over and checked the trailers wiring connection plug, to find it wasn't seated firmly. Had made a fairly tight U turn a few miles back, and the harness evidently did not have enough play, and pulled the connector part way out. Seemed to seat ok, afterwards, but used a bit of "hundred-mile-an-hour tape" just to be sure.
Seems like somewhere, sometime, there was a commentary on a RV board having to do with the wiring harness plug in and a tightner, clip or band that would guarantee that the wiring harness clip didn't wiggle/jiggle or otherwise pull loose. Have done a number of unsuccessful searchs, both here and elsewhere. Anybody have input on this topic?
Thanks
BillH
Sunny S.E. Colorado :sunny
Old 12-15-2002, 11:57 AM   #2
This is not new with me. I forget who showed me this trick, I think it was the master, Charles, when we were in Colorado.
Take a little bungy, the type with the ball on the end, and wrap it around the connector and the trap door on the receiver. The little door has a lip that catches the connector; and with the bungy holding it together tight, it won’t come loose.
Kinda what you did with the hundred-mile-an-hour tape only reusable.
I hope this helps.
Old 12-15-2002, 12:49 PM   #3
Velcro
Bill H,
I use a velcro strap around the door and connector, works great. I find it easier than the ball bungee.
Old 12-16-2002, 01:04 PM   #4
trailer plug holder
<img src=http://www.fiberglassrv.com/board/uploads/3dfe22a75b50dCasita Trailer plug holder.jpg/>
Here's the little bungee/ball and the plastic nut strap that Casita provides. Both available from wal-mart.....
........Bargmans idea of the little bump on the spring loaded flap doesn't seem to be enough.
Which harness Andre D Towing, Hitching, Axles and Running Gear 6 10-19-2008 02:51 PM
wiring harness blues ted saxton Care and Feeding of Molded Fiberglass Trailers 7 01-18-2008 11:27 AM
Hitch wiring plug options Lainey Problem Solving | Owners Helping Owners 5 07-20-2007 11:23 AM
Tow Hitch & Relay, Harness Questions V'sGlassSleeper Problem Solving | Owners Helping Owners 4 07-07-2007 08:32 PM
Can you plug into 120 while the 12v batteries are out? Cam A General Chat 0 01-01-1970 12:00 AM
