Wiring Issue - Fiberglass RV
Old 12-15-2010, 02:29 PM   #1
Trailer: 1980 16 ft Scamp (Restored)
Wiring Issue
I rewired my Scamp, all new wiring, terminals and fuse panel. I checked out the lights today(first good weather in three weeks!). Problem with trailer wiring (TV works OK).
With Trailer connected to TV:
Lights Switch on: All Tail & Marker lights on fine.
Left Blinker on: All " " " blink
Wiring description (TV plug):
1 O'clock - Tail (Grn)
3 O'clock - RH Blinker/Stop (Brn)
5 O'clock - Elect Brake (Blu)
7 O'clock - Ground (Wht)
9 O'clock - LH Blinker/Stop (Red)
11 O'clock - 12V (Blk)
I checked the wiring back to the taillights, ground/continuity OK. Could it be that I wired the tail & Blinker/Stop backwards at the taillights? I haven't checked that out yet, as it requires digging out the butyl putty sealant and removing the taillights. (Is there a way I could test this out without unhooking the taillights or cutting the wiring?) I tried swiitching the red and brn at the front terminal, with following results:
LH Blinker On: RH Blinker works.
RH Blinker On: Both Taillights bllink
Little help here, please.
Lawrence
Lawrence W is offline   Reply With Quote
Old 12-15-2010, 02:50 PM   #2
Lawrence, there's some wiring diagrams in the Document Center that may help:
Fiberglass RV - Document Center - WiringDiagram_7-Pin_TrailerEnd
Fiberglass RV - Document Center - WiringDiagram_7-Pin_CarEnd
Fiberglass RV - Document Center - WiringDiagram_Scamp
Old 12-15-2010, 06:58 PM   #3
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
If case you didn't catch it yet, you have the BLACK & GREEN wires reversed.
I was using the info in the Scamp manual.
Bill K
Old 12-15-2010, 07:01 PM   #4
Trailer: Fiber Stream
Cool
I tried switching the red and brown at the front terminal, with following results:
RH Blinker On: Both Taillights blink
My best guess is that you have some wiring crushed somewhere shorting red to something. When you switched the brown and the red, you effectively reversed the tail light positions, and the brown wire (LH Blinker on: RH Blinker works) works as I would expect it to, telling me you had them wired correctly the first time.
Looks like you have to dig out that putty. I would un-mount the tail light fixtures from the trailer's body, let them dangle from their wiring, and return the red and brown wires to their original positions at the front terminal. Test the operation from the tow vehicle's switch and see if they operate correctly.
In addition to checking the ground wire for continuity, you need to check each wire for resistivity to different colored wires. (You should not get continuity between red and brown, for example. Only between red and red.)
Old 12-15-2010, 07:40 PM   #5
Bill K
Bill:
My "O'clock" diagram is from the TV front view. I believe the Scamp Diagram is from the rear of the plug, which would mate up exactly with my setup. If the Scamp diagram is from the front, then, yes, my setup would be reversed.
Lawrence
Old 12-15-2010, 07:48 PM   #6
Fred:
thanks for the advice. I'll check it out tomorrow.( I was getting continuity between brn and all others.)
Q: (If I understand you correctly) If the RH blinker/brn worked correctly with the wiring reversed, then how could I have "wired it correctly the first time?" According to my (color coded) diagram, the brn is supposed to be the RH blinker/stop.
Lawrence
Old 12-15-2010, 08:52 PM   #7
Matt in SV's Avatar
Also - never trust the color code. Get a meter and check it out the continuity directly. I bought some etrailer pigtail and three of the wires were incorrect.
Regards,
Matt
Planning our next Escape!
Old 12-15-2010, 10:53 PM   #8
Regards,
Matt
Thanks, Matt,
As noted in my original thread, I rechecked from the TV plug, through the front terminal, rear terminal. I will go over everything again tomorrow, because I'm almost certain I have a short someplace. If I don't locate it, I will have to unbolt the taillights. I installed new ones, and the terminal clearances were very small, so...it could be there. I have good diagrams I made of everything, now I'll be able to practice troubleshooting.
Lawrence
Old 12-16-2010, 01:06 AM   #9
Matt in SV's Avatar
maybe you could remove all the bulbs, disconnect the trailer battery, and probe the pigtail connector for shorts between the various contacts??
Old 12-16-2010, 07:14 AM   #10
Lawrence,
If the Scamp view was opposite of yours then they all would be reversed not just two wires.
Bill K
Bill:
Lawrence
Old 12-17-2010, 09:19 AM   #11
Believe it or not, I solved the problem by simply replacing a taillight bulb that had one contact missing! Thanks to those of you who responded.
Lawrence
A/C Issue Georgana D Care and Feeding of Molded Fiberglass Trailers 8 07-28-2010 12:09 AM
Production Issue theresa p General Chat 3 04-14-2010 02:34 PM
Burro wiring issue Mike Magee Problem Solving | Owners Helping Owners 2 09-05-2009 09:26 PM
scamp wiring issue jmacchi Problem Solving | Owners Helping Owners 8 05-04-2009 07:52 PM
Scamp wiring issue llollio Problem Solving | Owners Helping Owners 9 05-06-2006 04:00 PM
