Wiring Questions - Page 2 - Fiberglass RV
Old 07-12-2007, 03:54 PM   #15
Dave Mac's Avatar
Trailer: Burro 13 ft 1979
I had a quick panic when I saw a red wire hooked to that ground strip in your picture but then I remembered that my 1700's water pump also has 2 red wires... The red one is positive and the red one is negative. I almost hooked the red one to negative once but wisened up just in time and hooked the red one to negative instead.
The only colors I could get for the brake wires were red and black. I'm looking for some blue tape to mark them with.
Dave Mac is offline   Reply With Quote
Old 07-12-2007, 04:18 PM   #16
Dave Mac's Avatar
I love the internet! Look what I found at www.trailerwiring.com .
Dave
Old 07-12-2007, 06:34 PM   #17
Brian B-P's Avatar
That's pretty much what I use, expect that one is better than mine in a way because it has a piggyback 4-way - if you tow a simple trailer that needs the 4-way, you don't have to unplug this adapter from the original 4-way. That feature would be even more valuable if the 7-way were hardwired in.
I see that adapter seems to use all four wires of the 4-way, plus has four individual wires (one of which is white with a ring terminal. In this case, they seem to be connecting to the 4-way's negative ("ground") connection plus providing an additional wire for the same terminal. In my case, the adapter didn't connect to the 4-way's white wire at all, forcing me to make a separate connection. In both cases, the intent is to provide a negative connection with higher current capacity than the lightly wired 4-way, which is necessary to use the brakes and/or charge line.
Old 07-12-2007, 06:36 PM   #18
Brian B-P's Avatar
That works, and should save confusion later. Electrical tape does come in blue, but I think a bit of blue heat-shrink tubing would be even better, since it's tidier and more likely to still be in place years later.
Old 07-12-2007, 06:45 PM   #19
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
Hopkins makes one of those. I bought two of those, one for each TV and wired one up. I also have a small sailboat trailer that is a 4 wire...
Pricey little things though... But worth it in my opinion.
Herb P is offline   Reply With Quote
Old 07-12-2007, 07:08 PM   #20
Dave Mac's Avatar
Ahh... good thought...
Old 07-12-2007, 07:10 PM   #21
Dave Mac's Avatar
In case you didn't see it here's my other "rig" that I need the 4 pin for.
Old 07-12-2007, 07:12 PM   #22
Greg A's Avatar
Trailer: 2015 Escape 19
That is the exact one I have on my Jeep Liberty. Great to be able to handle both types of connectors.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
RV Wiring Darwin Maring Problem Solving | Owners Helping Owners 8 01-27-2007 04:45 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
Newbie: Hitch & wiring questions Anne H Problem Solving | Owners Helping Owners 8 05-20-2006 04:17 AM
Wiring questions Paddy Morris Problem Solving | Owners Helping Owners 4 04-26-2006 03:28 PM
Wiring Questions, etc. Legacy Posts Problem Solving | Owners Helping Owners 6 06-03-2003 10:43 AM
