Wiring Questions - Fiberglass RV
Old 07-12-2007, 12:44 PM   #1
Dave Mac's Avatar
Trailer: Burro 13 ft 1979
As some of you know I have a new to me 1979 Burro. I have been re-wiring the brakes from hub to the front of the trailer. Now I am making these connections and discovering other problems I will be addressing.
First question: pictured below is a wiring "Lug". I am planing on connecting the incoming white from the tow cable to this lug. I am then going to connect all or most other white wires to this. The whites from my brakes and the other whites that were originaly wired together when I started. Does anyone see any problem with using this lug?
I will include a couple pictures of my wiring progress also.
Dave Mac is offline   Reply With Quote
Old 07-12-2007, 12:47 PM   #2
Dave Mac's Avatar
An error prevented my last picture going through on this post. Here is the picture of where I am now. This photo does not show the brake wires I have run. You can see I need somewhere to connect more white wires though.
Dave
Old 07-12-2007, 12:58 PM   #3
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
So basically you're making a common ground-strap... That's perfectly acceptable.
I've done something similar with a copper bar pre-threaded with #6-24 screws...
http://www.beer.org/gallery/Boler17-refresh/IMG_5485
There's a big bolt clamp at the end (easiest to see in the picture) where the incoming ground gets secured.
Herb P is offline   Reply With Quote
Old 07-12-2007, 01:17 PM   #4
Pete Dumbleton's Avatar
Scamp used a buss like that, but much shorter, to connect the 120VAC (green) ground from my breaker box to the frame It's sort of hidden in the fender well behind the left wheel.
On my 91S13, the 120VAC wiring is 'stand-alone', with the converter just plugged into an outlet to get it's AC power. Later Scamps appear to have the 120VAC hardware inside the converter.
Old 07-12-2007, 01:18 PM   #5
Dave Mac's Avatar
I kept reviewing this picture but could not quite see this set up you have because of the camera angle. But I assumed this is what you did.
Thanks
Old 07-12-2007, 01:23 PM   #6
Dave Mac's Avatar
I also need to somehow get a 7 pin female rv connection on my 1993 Jeep Wrangler. I have not found any with a quick connect wire harness for my vehical. So I'm thinking I will need to splice and wire it some how. Right now my jeep has a 4 pin flat on it that I did not install. Ineed to look and see if it was installed with a quick connction type set up or a splice and wire install. I might be able to utilize some of it if it was a quick connect type.
Anyway any one know of a 7 pin product specificaly for my Jeep?
Dave
Old 07-12-2007, 01:24 PM   #7
Dave Mac's Avatar
I'm looking at this for my 12 volt system for the wire harness connections not 110.
Old 07-12-2007, 01:35 PM   #8
Brian B-P's Avatar
I think that the bus bar is a great idea for the negative side of the 12 volt circuits. There are a lot of connections coming together in this case, and the bus bar gives each wire a secure connection to a common point. The bus bar idea is used both for grounds and for power circuits, in DC and AC, at low voltages and high - I think Pete was just giving one of these examples in support of the idea.
Old 07-12-2007, 01:42 PM   #9
Brian B-P's Avatar
My van has a dealer-installed wiring harness for the trailer lights which ends in a four-way flat connector. I used a 7-way socket which is designed for this situation, which is fed by a cable that plugs into the van's four-way connector for the light signals, plus separate wires which are connected to the brake, charge, and negative wires that I added.
If you don't want to do that, you can also just cut off the 4-way and replace it with a 7-way, if you can't find a complete harness to tap in the same way the 4-way does.
I would want to check how that 4-way is connected before deciding to use its wiring - hopefully there is an converter/isolator of some sort between the Jeep's light circuits and the trailer connector; a converter would be needed if the Jeep has separate brake and turn signals, but even if not, some isolation for circuit protection would be good.
Old 07-12-2007, 01:58 PM   #10
Herb P's Avatar
Yeah. If it would help, I can take more detailed pictures...
Old 07-12-2007, 03:31 PM   #11
Dave Mac's Avatar
Not needed but thanks.
Old 07-12-2007, 03:36 PM   #12
Dave Mac's Avatar
I have a feeling I will be removing the 4 way flat and utilizing the wires in it to install onto the 7 pin. Then adding the 3 wires/circuits need to complete the 7 pins. If I find the existing 4 way is installed with quick connectors I will feel much better about just using the wires at the 4 way connector as is. If no quick connect then I will trace back to where they were installed and see what I need to do to make my new connections there.
Dave
Old 07-12-2007, 03:52 PM   #13
Herb P's Avatar
I had a quick panic when I saw a red wire hooked to that ground strip in your picture but then I remembered that my 1700's water pump also has 2 red wires... The red one is positive and the red one is negative. I almost hooked the red one to negative once but wisened up just in time and hooked the red one to negative instead.
Old 07-12-2007, 03:52 PM   #14
Dave Mac's Avatar
Ok you guys...view these pictures at your own risk all right? They may cause flash backs!
I just wanted you all to see what I am seeing as I have been sticking my head in and out of cabinet spaces doing the brake wires. Some clown realy made a mess of this. Some of the cheapest splice connectors you could find. I guess your supposed to be able to press them on a bingo your off to the mountains! I keep finding them laying in the corners of the cabinet floors. And then I see little slices in the wires where they used to be and now I see bare wire. Not to mention I would guess the splicers are meant for a solid wire not a strand wire!?
Oh The Humanity!
RV Wiring Darwin Maring Problem Solving | Owners Helping Owners 8 01-27-2007 03:45 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
Newbie: Hitch & wiring questions Anne H Problem Solving | Owners Helping Owners 8 05-20-2006 04:17 AM
Wiring questions Paddy Morris Problem Solving | Owners Helping Owners 4 04-26-2006 03:28 PM
Wiring Questions, etc. Legacy Posts Problem Solving | Owners Helping Owners 6 06-03-2003 10:43 AM
