Wiring Solar - Fiberglass RV
Old 08-13-2009, 04:16 PM   #1
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Follow-Up question to mounting Solar Panels.
Wiring Solar into my Bigfoot electrical system. (I hope I can ask this clearly...)
When I add Solar panels to my trailer, I plan on using a controller to "regulate" the charge to my batteries.
My question is, What happens when I am on shore power and the batteries are being charge via the converter and the Solar panels at the same time? Can the shore power/converter hurt the controller? Or visa-versa?
Did that make sense?
Does anyone know of a Simple wiring diagram?
Old 08-13-2009, 04:26 PM   #2
Ed Harris's Avatar
Mike
The idea is to connect the various forms of charging all to the battery/s at the same point.
That way you are simply charging batteries with each of them when each are producing power and the battery acts as a "buffer" sort of to isolate the sources of charge from one another.
So as long as it is connected like that you can not hurt the chargers.
Ed
Ed Harris is online now   Reply With Quote
Old 08-13-2009, 05:55 PM   #3
Gina D.'s Avatar
West Coast USA
Nothing.
At least as far as your charge controller is concerned.
Once properly wired to the battery, it can stay as is and not be effected by any other charge method at all.
Ed is correct, the battery acts as a filter of sorts.
You'll be fine.
Old 08-13-2009, 06:43 PM   #4
Trailer: 1989 Bigfoot
Hi Mike, Most voltage regulators have a diode in them, power can only go to the battery from the solar panel. The voltage regulater (solar) will sense the batteries need for charging,and allow voltage to pass to the battery, but if you are plugged in to 110v and your battery charger is working on your converter the solar panel reg will shut down. Hope this helps
ken h is offline   Reply With Quote
Old 08-16-2009, 10:33 AM   #5
Joy A's Avatar
Mike,
It's a simple wiring. Just take the wires from the solar panel to the charge controller. Then take wires from the charge controller to the battery.
The charge controller will know when the battery needs to be charged and keeps the juice from flowing the other way, that is back to the panel. So, when on 110 the battery should be charged by the convertor and the charge controller will know that the battery doesn't need any juice from the solar panel, that is unless your convertor is failing to charge the battery.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
solar
solar hook up wiring question jimtesla Modifications, Alterations and Updates 3 05-07-2010 02:37 AM
PowerPole connectors for Solar Wiring OK? Pamela S. Problem Solving | Owners Helping Owners 7 01-23-2010 04:10 PM
RV Wiring Darwin Maring Problem Solving | Owners Helping Owners 8 01-27-2007 04:45 PM
How to hookup AC wiring? Tirah Care and Feeding of Molded Fiberglass Trailers 2 06-06-2006 07:03 AM
Wiring Gauge D Shubel Problem Solving | Owners Helping Owners 9 05-09-2006 05:44 PM
