Wiring tail lights in 76' Trillium - Fiberglass RV
Old 05-06-2015, 09:18 AM   #1
JRTrillium's Avatar
Name: Janice & Rick
Trailer: Trillium 1300
Nova Scotia
Hi All,
Our trailer will not pass safety until we repair our tail light. The passenger side was not bright at all. The mechanic said it was a grounding issue and when we took it off at home the ground post was broken.
Can someone please direct us to threads that contain wiring information?
When I do a 'search' and include the word 'wiring' I do not get the information we are looking for.
All suggestions and information is most welcome!
Thanks
Janice
p.s. I just noticed I became a 'senior' member
JRTrillium is offline   Reply With Quote
Old 05-06-2015, 09:23 AM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
You just need to repair the circuit to ground, Janice. Remove and clean up the existing ground point, and reattach with a new wire and connector.
I actually ran the ground wire right back to the tow vehicle, as well as grounded to the frame, with all the lights on the Trillium I rebuilt.
Oh, and congrats on the senior moment, they are coming more often for me too.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 05-06-2015, 11:15 AM   #3
Saskatchewan
As mentioned above with most trailers the ground just runs to the trailer - usually through the housing being mounted to the metal frame. The trillium lacks this metal frame, so you'll have to run a ground wire to each of the lights.
In my case the white wire from the truck plug runs throughout the trailer and uses ring terminals with crush washers to connect to each of the light fixtures - pretty straight forward to hook up, and easy to maintain.
dbir is offline   Reply With Quote
Old 05-06-2015, 11:35 AM   #4
IllAnnoy
Originally Posted by JRTrillium View Post
Hi All,
Thanks
Janice
maybe this will help you sort it out...
Trailer Wiring Diagrams | etrailer.com
Old 05-07-2015, 05:10 PM   #5
Roger C H's Avatar
Smile Horses not zebras
There is an old saying, "If you see hoof prints, suspect horses, not zebras."
We were having a problem with our left turn signal. It wouldn't work as a turn signal nor a brake light. After talking to the guy in the next site at Blake Ranch RV Park and Horse Corral, I plugged and unplugged the trailer hitch connector several times. (the connectors are the wipe type where they wipe each other when plugged and unplugged). It worked! The lights started working and have been working fine ever since. I do need to apply some silicone electrical grease.
light, lights, tail lights, trillium
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 09:10 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
Trillium 4500 Tail Lights Joe Loiacono Problem Solving | Owners Helping Owners 1 07-22-2007 06:51 AM
New Original Trillium Tail Lights D Martin Modifications, Alterations and Updates 9 01-23-2007 02:29 PM
Wiring Scamp tail lights Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 06-01-2003 08:50 PM
