wiring to the converter - Fiberglass RV
Old 06-02-2015, 09:55 AM   #1
Jay H's Avatar
Trailer: Boler 1300
Okay Folks, I need a little insight here. I usually photograph everything as I disassemble but I must have missed this. I am wanting to re-attach the wiring to the converter and I know the answer is simple but I don't want to do this wrong.
the Allanson converter has 3 wires on the 12 volt side. Blue, White, Red. the red connects to the positive terminal (so in my set up a black wire - which has been consistent throughout). the white and Blue complete the 12 volt load circuits. So here is the question:
1 - does the white from the battery negative terminal connect to the white wire in the converter?
2 - on the load circuit side (my lights are wired with white and black with white being -), I am assuming the white connects to the white in the converter (and the black load circuit wire connects to the blue?).
3 - essentially I guess I need to know which wire connects to the Blue wire to complete the load circuit?
here are a couple of pics, because everyone loves pics and hopefully they clarify my questions. Thanks for the help.
Jay H is offline   Reply With Quote
Old 06-02-2015, 10:26 AM   #2
red, white and blue...;)
the blue wire goes to your "unfiltered" DC circuits (powered by converter)
the red goes to the battery (positive)
the white is the ground (negative)
click on the pics for larger view
Old 06-03-2015, 08:31 PM   #3
Jay H's Avatar
Trailer: Boler 1300
Thanks Francois, that was what I needed. I know it seems silly to ask but I just needed to be sure. Wired it up this morning and it all worked great.
Scamp Wiring and Converter Questions kdhanso Electrical | Charging, Systems, Solar and Generators 11 07-01-2015 06:37 PM
Wiring from 12v Batteries to Converter in Casita cozygirl Electrical | Charging, Systems, Solar and Generators 26 03-24-2013 06:36 AM
Basic Wiring Questions for PD4045 Converter/Charger Ryan P R Electrical | Charging, Systems, Solar and Generators 11 10-03-2012 03:30 PM
Need help wiring a Powertron 300D converter Lisa A Problem Solving | Owners Helping Owners 4 03-03-2010 08:38 AM
Wiring Inverter, Converter, and Power Transfer Relays. GeorgeR Modifications, Alterations and Updates 3 01-31-2008 11:50 AM
