Wood floor replacement on a 13 ft boler - Fiberglass RV
Old 08-17-2015, 07:54 PM   #1
Trailer: Surfside tm14
So I have my frame out with only one small crack,now I want to replace the wood floor.is it best to leave the fiberglassed wood in place and just cut around the edge on like 30 degree angle and the same on the new piece? Or is there a better way.thanks form grande prairie ab
Rv tech is offline   Reply With Quote
Old 08-18-2015, 11:05 AM   #2
Johnny M's Avatar
Deep South
Some Boler's have a completely glassed in floor (later models) mine a 1971 had wood exposed floors glassed in around the edges of the body on both the top and underside of the floor. I cut through the top layer of fiberglass right at the body with a dremel plunge cut tool and left the underside glass in tack and slowly pulled and pryed to wood off so that the glass on the underside left a lip for my new wood to rest on to assist in getting the new wood floor to line up in the same spot all the way around the body. The front upper floor came out easily, the upper dinette was a challenge and I had to take it out in 3 pieces (save them and use it as a template to cut the new wood). The sides we a little difficult to remove with the wheel wells...I have a few pictures on my thread, Our 1971 13' Boler Mods.
Leaving the lip is important as if the body doesn't line up to the wood floor exactly the same it can cause the body to buck or twist which can cause stress cracks in places or even cause fit problems with your door.
boler
ZEP wood floor wax Mary Ann in MN General Chat 11 02-19-2014 07:59 PM
$5 re-store laminated wood floor Mcmarkrazz Modifications, Alterations and Updates 2 09-06-2013 01:31 PM
Installing a wood floor.... cpaharley2008 Modifications, Alterations and Updates 27 04-10-2013 07:45 AM
Trillium Jubilee Wood Floor Replacement rcaulen Problem Solving | Owners Helping Owners 4 08-31-2011 04:09 AM
Question – fiberglass repair– gap between wood-floor and “wall” of ori lenny247 Problem Solving | Owners Helping Owners 11 09-03-2006 03:27 PM
