Per speculation as to
weight of interior wood cabinetry etc.:
We do have
some accurate information per actual
weight of at least one wood interior:
Member here Ryan Parsons acquired and completely gutted a
Trillium Sportsman, a rear-entry model based on the 4500 that was delivered from the factory with an empty interior. Most folks did the finishing in wood, and this was no exception. Fortunately for us, Ryan weighed the ripped-out guts before disposing of them, and gives the weight of the wood alone he removed as 550 pounds- original quote below:
Originally Posted by ryan parsons
hi folks new to this forum so will try to be brief and accurate. I now own this trailer from the Kootenays. It is registered as A 1969 triple e Sportsman. Although it is a Trillium. I have completely gutted it as the worksmanship in side of it was good it weighed to much for the axles to bear. It weighs 1298 lbs empty spare tire and propane bottle (full) left on at weigh scales. I removed 550 lbs of plywood out of it and it was a real struggle to remove as all was glued nailed and screwed together. The remaining items water tank, heater, sink, icebox and stove top might weigh in at 100 lbs combined if I throw the micro wave and curtains in with the lot.
That quote is Ryan's first posting here, and is post number 53
at this link.
He did subsequently post a thread following the remodel, which can be seen/read at the following:
http://www.fiberglassrv.com/forums/f...man-57672.html
