Wood stove for 13 foot burro? - Fiberglass RV
Old 11-18-2013, 10:35 AM   #1
Trailer: Burr-ito
Hi,
I just picked up my first fiberglass trailer, i got a 13' burro. quickly nicknamed the burrito (little donkey)
I am primarily going to be using it as a winter weekend getaway in the mountains at a ski resort. The previous owner had it setup for summer camping with an conditioner.
I was wondering how other folks are heating their 13' fiberglass trailers? I saw online some tiny wood stoves but they still seem too big. like the Sardine from marine stoves (and not to mention, pretty darn expensive). it definately seems too big even at that size.
I guess i wouldn't even know where to put a wood stove with the chimney. anyone out there using a tiny tiny wood stove and can give me some advice?
thanks
pete
not-very-clever is offline   Reply With Quote
Old 11-18-2013, 10:50 AM   #2
In a word: "Fergetit" Beyond the obvious fire hazard and potential for leaks, hauling wood up, as well as ashes back down, will become a real PITA.
One of the Atwood LP heaters, commonly used in a lot of FGRV's, is called the "Everest Star" for good reason. They have been used to heat tents at Everest base camps and will turn your little burro into an oven in no time flat. Here is a link to the family:
Everest Star 7900 II Series Heating System - Atwood Mobile
These are designed for RV use and are reliable and safe. Yep, you might have to recharge a battery now and then, but you will be as warm as toast in the coldest weather. And you won't have to get up in the middle of the night to relight the stove.
IMHO: Wood Stoves in RV's = A Bad Idea, but that doesn't prevent some from using them.....
Old 11-18-2013, 10:58 AM   #3
Trailer: Compact Junior
I sure wouldn't use a wood stove while asleep, and would want a carbon monoxide detector on board too.
And would be very careful with venting and a proper stove pipe.
But if you just have to have one you might check out one of these:
bpLite • View topic - FATSCO Stoves Wood burnning stoves for boats
There is a link to the stove maker's website at this site.
These little stoves are about the size of a coffee can and were first made in Benton Harbor, Michigan. They were made for warming up milkmen on their routes in horse-drawn wagons.
john madill is offline   Reply With Quote
Old 11-18-2013, 02:00 PM   #4
ShawnKK's Avatar
Ever hear of RMH or just Rocket stoves? I just made one as a prototype and they work great. You can make a Rocket stove that does a reburn of the gases and no smoke. There are alot of vides on YouTube on these and some installed in campers. I say go for it if you have a place for it!
ShawnKK is offline   Reply With Quote
Old 11-18-2013, 02:02 PM   #5
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Here is the top of the line of wood stove very expensive though but it will last a life time and its portable you can use it in you house, shop, boat, and trailer.
Wood Stoves & Beyond |
And then there is this one.
Pipsqueak | Small Cast Iron Stove
And of course a cheep one.
Nu-Way Stoves, Model 965, Wood Burning Stove, Ventilation, Stove Pipe Kit, Ash Pan, Low Pressure Regulator, Deer Blinds, Ice Fishing, Grayling, Indian River, Cheboygan
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 11-18-2013, 02:22 PM   #6
US
RV Woodstove
install video here
Old 11-23-2013, 10:05 PM   #7
MyronL's Avatar
Trailer: Escape
New Mexico
A friend of a friend found out the biggest thing about using wood stoves in a camper for overnight heat is the near guarantee that if you keep the windows closed to keep the heat in --you are likely to wake up very dead the next morning.
MyronL is offline   Reply With Quote
Old 11-23-2013, 10:20 PM   #8
I recall staying in a log cabin in northern B.C. one night. I loaded up the air-tight wood stove with green wood before crawling into bed. It was 26 degrees below zero.
Did I mention I too was loaded?
Woke up about 4 am and the air-tight stove was bouncing up and down from the intense heat inside, and out. Must have been 130 degrees in the cabin, but at least it wasn't on fire.
With no mind of the blizzard outside, I opened the cabin door, and went back to bed.
If you want to be warm in a 13' trailer, I highly recommend a wood stove.
Old 11-23-2013, 11:16 PM   #9
LeonardS's Avatar
Trailer: not yet
I heated my home for 16 years with wood. One issue with trying to heat a 13 foot camper...the size ratio of wood stove to camper is just not ideal. Sizing a stove to the room it is heating is always critical. BTU output, the amount of fuel that can be loaded into the firebox, rate of burn...you're usually trying to get the right mix that will put out enough heat and still last at least 6 hours, preferably 8, with a full fuel load. Smaller stove for smaller rooms start to get out of the ideal mix pretty quick.
In other words, a stove for a camper would have to be so small that the firebox wouldn't be able to hold enough wood to last long enough to heat through a night.
Now...a itty bitty pellet stove...that might work. But it would take battery power to operate. And you'd have to have a CO detector, and good venting, and likely a cold air combustion air source.
LeonardS is offline   Reply With Quote
Old 11-24-2013, 05:14 AM   #10
Raz
Raz's Avatar
Vermont
Besides the space issue and the fact that fiberglass is very combustible, there's where to put the chimney. You would need to have at least 10 feet of stove pipe strait up. For every bend add 2-3 feet. Without that you will quickly fill the living space with smoke every time you go to put wood in the stove. That is, if you can get it started. The chimney is what makes a wood stove work. Please, cross this one off the list. Raz
Old 11-24-2013, 08:04 AM   #11
kirkman's Avatar
Here is a off the grid pellet stove that does not use any power.
Clarry Pellet Stove, off-the-grid heat, *powerless pellet stove, hunting, wall tents, line shack, ice fishing, out-buildings
And you could always try a charcoal heater like they use on boats. here are some directions on how to make your own.
Make a Simple Solid Fuel Stove For Your Boat
And here is one more small boat wood /coal stove.
ShipMate Stove Company Inc. - your source for classic solid fuel boat stoves, heaters and sinks.
Jason
Old 11-24-2013, 08:16 AM   #12
Hmmmm Over 150 degrees inside/outside temp spread in a cabin with a wood stove. I think you should contact Guiness (?) and get that listed as a record.
Seriously, you pointed out several reasons to not have a wood stove in an RV.
Old 11-24-2013, 08:19 AM   #13
kirkman's Avatar
Here is a small charcoal stove.
Jason
Old 11-24-2013, 08:31 AM   #14
kirkman's Avatar
Here is a video on installing a Kimberly wood stove in a RV. It can and has been done very successfully.
Here is another video of the Kimberly being used in a RV.
Jason
burro
looking for a 17 foot burro the3carrs Wanted: Molded Fiberglass Travel Trailers 2 05-01-2012 08:23 AM
Project Burro- 1978 Burro 13 foot Scott B. Classified Archives 0 08-09-2009 11:19 PM
Wood stove!!?? & other 'cool' things...... Penney H. & Mike E. General Chat 8 03-02-2009 08:19 PM
Another wood stove alternative Bonnie General Chat 9 12-22-2008 07:07 PM
Wood Stove Legacy Posts Jokes, Stories & Tall Tales 1 10-12-2002 06:26 AM
