Wooden horizontal supports: how to replace? - Fiberglass RV
Old 01-19-2016, 10:47 AM   #1
Trailer: 1975 Boler
Quebec
Any hints on replacing the wooden support at each end of the Boler? They are used to support the table at one end and the top bunk at the other...
Uncle Cereal is offline   Reply With Quote
Old 01-19-2016, 12:00 PM   #2
Trailer: 77 Scamp 13
Are they wood fiberglassed to the wall? That is called tabbing, and the Google site search under the search link (upper right navigation bar) might bring up some posts on the replacement process if you search for that. Otherwise I'm sure someone that has done it will chime in soon.
Old 01-19-2016, 01:14 PM   #3
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
They are both fiberglassed into place. if you need to make new ones the old ones can be used as patterns if not some cardboard and lots of trimming to get the shape and then epoxy or PL Builders glue to the wall and fiberglass to permanently mount it.
Rick Mooyman is offline   Reply With Quote
Old 01-19-2016, 01:27 PM   #4
Trailer: 1975 Boler
Quebec
Roger and Rick, thank you both: very useful! The "tabbing" search gives mostly "cabinet tabbing" results, but I'll look some more and I think it's very "doable"...
Old 02-05-2016, 11:50 PM   #5
Trailer: 1975 Boler
Quebec
Here are the most interesting related threads I found.
Scamp bunk mount dimensions & window ?
"Tabbing"
Tabbing
Roger, you didn't want to brag about it, but you did quite a job on yours!
It doesn't seem hard but quite a job regardless! I might wait a few months before I tackle that job. I'm not sure how to move ensolite out of the way for tabbing...
P.S.: This seems useful.
Old 02-09-2016, 08:56 PM   #6
Trailer: 1975 Boler
Quebec
Does anyone have a clue on how to remove the ensolite in order to do the tabbing of the new board?
Old 02-09-2016, 09:28 PM   #7
I used a wood chisel to cut out where I bonded in the bulkheads and cabinets.
A wire brush and drill to rough up the surface.
Sent from my SCH-I605 using Fiberglass RV mobile app
how to replace wall supports on a scamp mojowheeler Problem Solving | Owners Helping Owners 6 06-09-2014 10:01 PM
Use of Captain Tolley's on Horizontal Surfaces CampyTime Care and Feeding of Molded Fiberglass Trailers 20 01-08-2014 08:46 PM
Replacing wooden lip that supports benches mary b. Problem Solving | Owners Helping Owners 8 10-04-2013 08:21 AM
Wanted: 30# Horizontal propane tank Lisa H. Classified Archives 3 07-17-2009 12:00 AM
SOLD ~ Horizontal propane tank for sale jeanne Classified Archives 1 04-19-2008 11:13 PM
