Worst job ever! - Fiberglass RV
Old 04-20-2012, 10:57 PM   #1
Perry J's Avatar
Trailer: 16' Casita
Worst job ever!
I've refurbished at least 7 or 8 eggs since I retired.
I decided to remove the stripes on the side of my little Bigfoot today.
This is the only thing I've never done and it's a, I won't tell you what it is.
I did the search and came up with 1250 other threads.
Can anyone tell me if there is an easy way?
I spent the afternoon with a hair dryer and a razor scraper and removed one of the three stripes on one side.
HELP!
John
Old 04-20-2012, 11:08 PM   #2
LukeP's Avatar
Iowa
my experience is that a heat gun makes the job go a lot faster than a hair dryer. I don't know how much hotter it gets than a standard hair dryer, but it makes a big difference in the ease of the job. maybe some one else will have other experiences... good luck!
LukeP is offline   Reply With Quote
Old 04-20-2012, 11:19 PM   #3
IllAnnoy
HELP!
John
Lose the razor scraper and get a plastic one, The metal one can harm the Gelcoat. The plastic one works just as well and you don't have to be as careful (read a bit faster).
Once the vinyl is off use waterless handcleaner to remove most of the residue, wipe it down with isoprpyl, then buff it with GelGloss or wax.
The best you can hope for is a little ghosting in the right light.
Or...
You could use one of these but BE CAREFUL!
Grimco - Tape | Tools: Vinyl and Film Removal Tools, Stripe Eliminator
Old 04-20-2012, 11:22 PM   #4
IllAnnoy
A lot! but it is faster. A heat gun must be kept moving to avoid softening the gelcoat. That's when you really need the plastic scraper instead of metal or razor blade.
Old 04-21-2012, 05:06 AM   #5
Depends on what you think your time and aggrevation is worth. Some people want to spend zero dollars and lots of time, others are willing to spend some money and use little time. YOU may find this topic of value: Removing Stripes
I know if it was me, I'd be buying the rubber eraser... YMMV
Old 04-21-2012, 08:52 AM   #6
MFF
Trailer: Boler-1300 1979
Quebec
We just finished doing so and the result is really good ! We used the rubber eraser. It did not take much time or effort...
MFF is offline   Reply With Quote
Old 04-21-2012, 08:58 AM   #7
Perry J's Avatar
Trailer: 16' Casita
Thanks everyone.
I just ordered a 3M stripe off wheel from Amazon.
John
Old 04-21-2012, 09:38 AM   #8
Perry once you've used the rubber eraser let us know how it worked out. More than one opinion about a tool is always a good thing
Old 04-21-2012, 11:08 AM   #9
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Like Floyd said, "lose the razor" or you may be repainting.
Old 04-21-2012, 11:35 AM   #10
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Use a heat gun and a credit card, took me 5 minutes each side.
Before (remove top stripe and sticker below porch light)
After
Old 04-21-2012, 04:21 PM   #11
Perry J's Avatar
Trailer: 16' Casita
I used a hair dryer and it removed the newer 2" tape that covered the original tape.
The 3 original stripes are weather cracked and baked on to the fiberglass.
I borrowed a neighbors heat gun this morning and it did very little.
I was going to drive to Bakersfield to pick up a rubber eraser but the second day shipping cost is about 1/2 the cost of the gas for the trip.
Before $4.00 + gas I didn't think about making the trip.
I will let you all know how it worked out.
Thanks again.
John
Old 04-25-2012, 09:13 PM   #12
Perry J's Avatar
Trailer: 16' Casita
The 3M Stripe Remover wheel worked very well removing the 24 year old baked on stripes.
I used it in my 3/8 drill.
I ordered it from Amazon and was pleased with the price and even more pleased with the quick delivery.
I found I needed to lightly wet sand some of the area to remove some of the baked on, dried out glue from the tape.
I discovered another great use.
The top and bottom of the Belly band was sealed with 24 year old silicone.
The wheel removed the silicone with absolutely no problem.
John
Old 04-25-2012, 09:34 PM   #13
Trailer: 77 Scamp 13
I used the 3M Stripe Remover and was very pleased. Ran it off of my 1/2 inch drill which has a lower speed range than my 3/8 drill. ALWAYS good to hear about anything that removes silicone. Have that same belly band caulk as Perry J to remove so I will give that a try.
Best/worst floors? Amy M Care and Feeding of Molded Fiberglass Trailers 7 11-05-2009 11:43 AM
Second worst joke Byron Kinnaman Jokes, Stories & Tall Tales 3 10-16-2006 10:51 PM
Worst Halloween Joke ever Rick Jokes, Stories & Tall Tales 5 10-16-2006 09:18 PM
Assuming the worst jdtrotter Jokes, Stories & Tall Tales 7 02-07-2006 08:29 PM
Worst headlines of 2002 Legacy Posts Jokes, Stories & Tall Tales 6 02-08-2003 07:18 PM
